Date/Time: Tue, 16 Apr 2024 16:08:14 +0000
Auto Retracement/ Projection missing the .236 for projection
View Count: 1528
[2013-08-14 16:22:07]
Jerry J Sears - Posts: 27
When I have the Auto Retracement/ Projection then do the manual method the .236 for projection is missing even though I have it turned on. It works for retracement. Any ideas?
Let me know,
Jerry
[2013-08-14 16:38:27]
vegasfoster - Posts: 444
Tools>>Tool Configs>>Price Expansion Config and make sure the 23.6 is checked. If it isn't there, then you can add it.
[2013-08-14 17:49:11]
Hi vegasfoster,
My concern is with the Auto Retracement/Projection study not the tool.
Any other ideas?
Thanks,
Jerry
[2013-08-14 19:22:07]
Go to the Subgraphs tab of the Study Settings window for the Auto Retracement/Projection study and check the Draw Style for the Level # Subgraph that you want to see. And make sure it is set to a visible style.
[2013-08-14 20:25:19]
Ok,
I fixed it by adding another Auto retracement/projection set to retracement and use the low.
Thanks,
Jerry
