Date/Time: Tue, 23 Apr 2024 08:06:09 +0000
Symbol is unknown message with new version using CTS
View Count: 1779
[2013-08-14 13:29:58] |
Futurestrader77 - Posts: 126 |
Hello, with the new version I´m getting the message that the symbol is unknown. Im using CTS as data feed. Best regards |
[2013-08-14 17:01:20] |
You need to change the symbols to the new format. This is explained here: http://www.sierrachart.com/index.php?l=doc/CTS_T4.php#UsingFIX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-15 06:25:50] |
Ok, thank you very much! Best regards, Thomas |
