Date/Time: Fri, 29 Mar 2024 13:43:52 +0000
replay market spread
View Count: 1385
[2013-08-13 19:48:41] |
Cristian.Ivanov - Posts: 9 |
I'm using SC Forex Data. When trading live the spread is okay but when replaying charts the spread in 0.5 pips no matter what. Can this be adjusted if the real spread is not available on replay? |
[2013-08-14 00:14:51] |
Yes. This can be adjusted by adjusting the Tick Size in Chart >> Chart Settings. This is documented here: http://www.sierrachart.com/index.php?l=doc/doc_TradeSimulation.php#TradeSimulationBidAskPrices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-14 00:16:11
