Date/Time: Fri, 29 Mar 2024 11:34:29 +0000
Quote Board sorting
View Count: 1362
[2013-08-13 15:51:04] |
rascal - Posts: 9 |
When the quote board is set to sort on a column with dynamically changing values such as NetChange%, it does not reorder the rows correctly as the values change.
[2013-08-14 00:10:46] |
We did not see this particular problem. However, while testing this we did notice another issue with the display of some of the fields when sorting is used on the rows. Update to the latest release by selecting Help >> Download Current Version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
