Date/Time: Thu, 25 Apr 2024 14:25:03 +0000
[User Discussion] - Volume By Price on TradeDOM
View Count: 1430
[2013-08-13 00:02:07] |
eagle - Posts: 92 |
I have some problems with the Volume By Price study on TradeDOMs. Volume values do not display correctly when the Display Volume in Bars input is set on "Ask Volume - Bid Volume", or set on "Bid Volume - Ask Volume", or set on "Ask Volume - Bid Volume, TotalVolume". When the Right Align Volume Bars input is set on "Yes", the bid volume and the ask volume color subgraphs are reversed in their left/right positions. This maintains the bid volume color at the base of the bars, but it seems to me that the ask volume color should be shifted to the base in order to maintain proper left/right correlation with the volume value numbers. When the Align Volume Numbers To Base Of Volume Bars input is set on "No", it always reverts to "Yes". A No setting will not stick. I don't know if this is actually a problem because I don't know what this input is supposed to accomplish. When the Align To Far Right input is set on "Yes", it seems to have no effect at all on the display. |
[2013-08-14 00:18:42] |
We have reviewed this and we have updated the documentation as best as we can to answer these questions. Please refer to the Volume by Price Input Settings here for all of these settings in question: http://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html#Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
