Date/Time: Wed, 24 Apr 2024 06:04:32 +0000
Stop order not visible in chart trader IB
View Count: 1771
[2013-08-12 20:20:09] |
Miracle 007 - Posts: 17 |
I'm using chart trader. I can enter a position using bracket order and the limit shows up, but not the stop order. Both orders are listed in IB platform. The bracket order works and is visible in the simulation mode. Date Time Of Last Edit: 2013-08-12 20:22:42
ibsierra.jpg / V - Attached On 2013-08-12 20:20:03 UTC - Size: 55.84 KB - 466 views |
[2013-08-12 20:38:14] |
Here is the order log.
Date Time Of Last Edit: 2013-08-12 20:38:46
orders.jpg / V - Attached On 2013-08-12 20:38:39 UTC - Size: 565.42 KB - 481 views Attachment Deleted. |
[2013-08-12 21:29:04] |
After looking at orders and positions window I think the stop order was somehow deactivated.
[2013-08-13 04:22:38] |
Do you consistently notice this problem where the stop has a price of 0?
[2013-08-14 00:55:11] |
I submitted another bracket order and it did the same thing. If I reboot both TWS and SC, the stop order is visible on the SC chart. I think it is a problem with TWS because the dropdown box on the stop order was not in the proper increments normal to that contract. I'm going to try to install an older version of TWS. Do you have a certain version of TWS that works best with SC?
Date Time Of Last Edit: 2013-08-14 01:06:27
[2013-08-14 02:08:00] |
We cannot comment about TWS versions. We do not know. At best you might need to restart Trader Workstation. Restarting Sierra Chart will not help with a problem like this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-14 02:08:41
