Date/Time: Wed, 24 Apr 2024 11:09:32 +0000
Using 2 monitors on 1 computer for charts
View Count: 2179
[2013-08-12 16:51:11] |
M5amhan - Posts: 468 |
try using Window > Attach/Detach Chart Window if you haven't already
[2013-08-12 23:13:43] |
Here is the documentation to detach and attach charts from/to the main window: http://www.sierrachart.com/index.php?l=doc/doc_DetachingandAttachingChartWindows.html Here is the documentation for linking a Quote Board to charts: http://www.sierrachart.com/index.php?l=doc/doc_GettingQuotes.html#ChangingSymbolOfChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-12 23:14:01
