Date/Time: Tue, 23 Apr 2024 06:11:14 +0000
Is there a method to draw a 50% value line to a short timeframe swing?
View Count: 1531
[2013-08-11 14:44:21] |
janos bardon - Posts: 36 |
Hello, could I somehow determine for example where is the 50% value of a short time frame swing? I don't want every time the difference of the high and the low divide by two, I'd like to find a graphic method to do this, like Fibonacci tool elsewhere.
[2013-08-12 13:03:57] |
vegasfoster - Posts: 444 |
Tools>>Price Retracement
[2013-08-12 19:19:36] |
thank you
[2013-08-12 22:40:35] |
Here is the documentation for the Price Retracement tool: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#RetracementExpansionProjection Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-13 06:46:15] |
thank you too
