Date/Time: Fri, 19 Apr 2024 20:20:46 +0000
New User OEC Broker Setup
View Count: 1579
[2013-08-10 20:22:26] |
kleros - Posts: 21 |
I have successfully set up Sierra Chart to work with OEC. Do I need to set up Sierra Chart Futures back-fill as well? Chris |
[2013-08-10 22:50:35] |
There is nothing special to do in newer Sierra Chart versions to use the enhanced historical data available for OEC users. This is automatic.
[2013-08-15 03:26:05] |
Willson - Posts: 176 |
""I have successfully set up Sierra Chart to work with OEC."" Hi Chris, I want to do the same. Could you outline how you setup Sc to use OEC data and trading, I would appreciate any hints and methods. Regards, willis |
[2013-08-15 04:29:54] |
You can find documentation for this here: http://www.sierrachart.com/index.php?l=doc/openecry.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
