Date/Time: Sat, 05 Sep 2026 17:55:30 +0000
User Email
View Count: 1146
| [2017-01-03 18:01:21] |
I currently have a trading account and I trade with Xtrader. I would like to know if I can connect my TT data stream to sierra. Or if I'm forced to take another stream in parallel? Thank you for your comeback. Thank you for confirming that TT data streams are supported on sierra. My broker AMP say no. Sierra Chart Support |
| [2017-01-03 18:09:27] |
The TT data feed is not supported in Sierra Chart unless it comes from a FIX Adapter: http://www.sierrachart.com/index.php?page=doc/TradingTechnologies.php If your broker is AMP, then this is definitely not supported any longer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-01-04 16:12:51] |
From User: Thank you for your response.
If I take CQG data from my AMP broker, then I could benefit from all market internals as TICK, TRIN, ESINX...? Sierra Chart Support |
| [2017-01-04 18:11:08] |
Market statistics are provided: http://www.sierrachart.com/index.php?page=doc/SCMarketStatistics.php For the stock index futures premiums, requires that you pay for and activate the Sierra Chart Exchange Data Feed: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#StockIndexPremiums Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
