Date/Time: Tue, 23 Apr 2024 08:01:09 +0000
Data Difference
View Count: 977
[2016-11-30 14:59:01] |
User426107 - Posts: 9 |
So I was told that EP is the symbol for emini S&P of which I have always traded with that symbol being ES. I am having problems because I am just using Sierra with CQG data feed for execution and that symbol is way off as compared to the charts I look at with ES on my multiple other data sources? Why would this be? It is a big problem for me to have such a large difference. Could someone call me or email me? I would like some personal support on this to figure this out.
[2016-11-30 16:47:48] |
my email is camerondnelson@gmail.com. If someone could email me and get my phone number or something I would appreciate it. My data with Sierra and CQG on symbol I was told is just way off from the other data I am using so I don't know what I am doing wrong
[2016-11-30 16:58:30] |
I believe data is correct but it appears to be delayed by about 10 minutes
[2016-11-30 17:12:26] |
In regards to post #1, there was a time stamping issue on the server which was resolved about 30 minutes ago. It was off by about two seconds and affected historical data since about 2016-11-29. This has caused some differences with chart bars compared to charts using data from other services. This is now corrected. Go to the chart and re-download the data with Edit >>Delete All Data and Download. I believe data is correct but it appears to be delayed by about 10 minutes So the chart updating is delayed by 10 minutes? Or is it not updating at all?
[2016-11-30 17:20:32] |
The data is correct but the time is delayed by around 10 minutes.
[2016-11-30 17:21:42] |
Like on the DOM which I am trying to use for execution it is showing the price at the spot where based on my other data it was about 10 minutes ago
[2016-11-30 17:42:30] |
First understand that we do not control the market data. That is controlled by your broker. Therefore, if the data is delayed you need to contact your broker about that. Provide a copy of the Message Log by following these instructions: https://www.sierrachart.com/index.php?l=doc/PostingInformation.php#MessageLog We will look at the Message Log and see what we can tell from that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-30 17:54:42] |
That's why I contacted them first but they said to contact you so I don't know what to do
[2016-11-30 17:55:54] |
Reading Internal Order ID file. | 2016-11-29 17:32:29 Reading Trade Orders file. | 2016-11-29 17:32:29 Reading Trade Positions file. | 2016-11-29 17:32:29 Software version: 1488 | 2016-11-29 17:32:29 Uses New Spreadsheets | 2016-11-29 17:32:29 Usage end date: 2016-12-07 | 2016-11-29 17:32:29 Enabled for: Advanced Features. | 2016-11-29 17:32:29 Enabled for: Advanced Features 2. | 2016-11-29 17:32:29 Enabled for: Sierra Chart Historical Data Service. | 2016-11-29 17:32:29 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-11-29 17:32:29 Current selected Data/Trading service: CQG FIX Trading | 2016-11-29 17:32:29 Chart Update Interval: 500 | 2016-11-29 17:32:29 Time Zone: +00:00:00 (UTC+00) | 2016-11-29 17:32:29 2016-11-29 09:32:32 Local computer time | 2016-11-29 17:32:29 2016-11-29 17:32:32 Local computer time in UTC | 2016-11-29 17:32:29 2016-11-29 17:32:32 Local computer time in SC Time Zone | 2016-11-29 17:32:29 2016-11-29 17:32:29 Server time in UTC | 2016-11-29 17:32:29 Local computer UTC time and Server UTC time difference: 3 seconds. | 2016-11-29 17:32:29 Program path: C:\SierraChart\ | 2016-11-29 17:32:29 Data Files path: C:\SierraChart\Data\ | 2016-11-29 17:32:29 OS Version Number: 6.2 | 2016-11-29 17:32:29 Locale Setting: C | 2016-11-29 17:32:29 Checking for new symbol settings for cqg | 2016-11-29 17:32:29 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-11-29 17:32:29 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-11-29 17:32:29 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-11-29 17:32:29 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-11-29 17:32:33 Symbol settings are up-to-date for cqg | 2016-11-29 17:32:34 CQG WebAPI | Connecting to market data server api.cqg.com | 2016-11-30 16:44:41 CQG WebAPI | Connecting to websocket server. | 2016-11-30 16:44:41 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-11-30 16:44:42 CQG WebAPI websocket (742) | Connected. | 2016-11-30 16:44:42 CQG WebAPI websocket (742) | Starting SSL 3/2 connection. | 2016-11-30 16:44:42 CQG WebAPI websocket (742) | SSL connection established. | 2016-11-30 16:44:42 CQG WebAPI | Opening websocket. | 2016-11-30 16:44:42 CQG WebAPI | Sending websocket handshake. | 2016-11-30 16:44:42 CQG WebAPI | Received websocket handshake acknowledgment. | 2016-11-30 16:44:42 CQG WebAPI | Web socket state is now open. | 2016-11-30 16:44:42 CQG WebAPI | Websocket connected. | 2016-11-30 16:44:42 CQG WebAPI | Sending market data logon message. | 2016-11-30 16:44:42 CQG WebAPI | Logon successful. Session Token = oAOdFZF7IXEeoCm7MVC3TgReqdAKZaXw0DSaK31E63U | 2016-11-30 16:44:42 CQG WebAPI | Connected to data and trading server. | 2016-11-30 16:44:42 CQG WebAPI | Sending Trade Accounts request message. | 2016-11-30 16:44:42 CQG WebAPI | Starting real-time market data updates for: F.US.EPZ16. ID: 1 | 2016-11-30 16:44:42 CQG WebAPI | Sending symbol resolution request for F.US.EPZ16. ID: 952776 | 2016-11-30 16:44:42 CQG WebAPI | Requesting security definition data for: F.US.EPZ16. ID: 1 | 2016-11-30 16:44:42 Intraday data recording state for symbol F.US.EPZ16 is set to download 'Pending'. | 2016-11-30 16:44:42 Market data subscription status is not known while delaying historical data download for symbol: F.US.EPZ16 | 2016-11-30 16:44:42 Delaying start of download for F.US.EPZ16 | 2016-11-30 16:44:42 CQG WebAPI | Brokerage name: Advantage Account Name: Cameron Nelos | 2016-11-30 16:44:42 CQG WebAPI | Sending collateral subscribe request. | 2016-11-30 16:44:42 CQG WebAPI | Received symbol resolution report for symbol F.US.EPZ6. Search Symbol: F.US.EPZ16. Request ID: 952776. Contract ID: 1. | 2016-11-30 16:44:42 CQG WebAPI | Requesting market data for F.US.EPZ16 | 2016-11-30 16:44:42 CQG WebAPI | CQG User message | Info: Data is available again. | Source: Web API Server | 2016-11-30 16:44:42 * Delaying start of download for F.US.EPZ16 | 2016-11-30 16:44:43 HTTPS connection to www.sierrachart.com:443 (741) | SSL connection closed by remote side. | 2016-11-30 16:44:45 HTTPS connection to www.sierrachart.com:443 (741) | Connection gracefully closed by remote side. | 2016-11-30 16:44:45 HTTPS connection to www.sierrachart.com:443 (741) | SSL object has been freed. SSL state is now disconnected. | 2016-11-30 16:44:45 HTTPS connection to www.sierrachart.com:443 (741) | Shutdown and closed. | 2016-11-30 16:44:45 CQG WebAPI | Sending positions subscribe request. RequestID=952780 | 2016-11-30 16:44:47 CQG WebAPI | Sending orders subscribe request. RequestID=952781 | 2016-11-30 16:44:47 Requesting market depth updates for: F.US.EPZ16 if supported. | 2016-11-30 16:44:47 CQG WebAPI | Requesting market data including full depth for F.US.EPZ16 | 2016-11-30 16:44:47 HD Request # 10 | Downloading Intraday chart data for F.US.EPZ16 to the file F.US.EPZ16.scid. Service: cqg | 2016-11-30 16:44:47 HD Request # 10 | Download start date-time: 2016-11-30 16:34:06.000 | 2016-11-30 16:44:47 HD Request # 10 | Using server: ds3.sierracharts.com port 10149 | 2016-11-30 16:44:47 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-11-30 16:44:47 Socket (743) | Connected. | 2016-11-30 16:44:47 HD Request # 10 | Setting DTC encoding to Binary VLS | 2016-11-30 16:44:47 HD Request # 10 | Sending historical data logon request message. | 2016-11-30 16:44:47 HD Request # 10 | Requesting Intraday data. Start date-time: 2016-11-30 16:34:06. Record interval: 1. Symbol: F.US.EPZ16 | 2016-11-30 16:44:48 HD Request # 10 | Decompressing data. | 2016-11-30 16:44:48 HD Request # 10 | Receiving Intraday data for F.US.EPZ16 starting at 2016-11-30 16:34:06 | 2016-11-30 16:44:48 HD Request # 10 | Timestamp of first Intraday data file record written: 2016-11-30 16:34:06 | 2016-11-30 16:44:48 Socket (743) | Shutdown and closed. | 2016-11-30 16:44:48 The network socket for historical data has been closed. | 2016-11-30 16:44:48 HD Request # 10 | Received 434 records from 2016-11-30 16:34:06 to 2016-11-30 16:44:20 (10.2 minutes) and wrote 434 records for F.US.EPZ16 | 2016-11-30 16:44:48 HD Request # 10 | Intraday download COMPLETE for F.US.EPZ16. Completion time: 0s. Unique request ID: 9 | 2016-11-30 16:44:48 Removed historical data download ID 9 | 2016-11-30 16:44:48 Real-time Intraday chart data file updates started for F.US.EPZ16 | 2016-11-30 16:44:48 Opened cached Intraday file: C:\SierraChart\Data\F.US.EPZ16.scid | 2016-11-30 16:44:48 Intraday chart data file opened for F.US.EPZ16 | 2016-11-30 16:44:48 F.US.EPZ16 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-11-30 08:40:00. Next Bar Date Time: 2016-11-30 08:30:00. Filename: F.US.EPZ16.scid | 2016-11-30 16:44:48 CQG WebAPI | Sending positions unsubscribe request. RequestID=952780 | 2016-11-30 17:32:33 CQG WebAPI | Sending positions subscribe request. RequestID=952783 | 2016-11-30 17:32:33 CQG WebAPI | Sending orders unsubscribe request. RequestID=952781 | 2016-11-30 17:32:33 CQG WebAPI | Sending orders subscribe request. RequestID=952784 | 2016-11-30 17:32:33 Date Time Of Last Edit: 2016-11-30 18:03:09
[2016-11-30 18:02:33] |
Please set your telephone number here: https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo Let us know when that is done and we will give you a call to look into this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-30 19:22:54] |
I put my phone number in htere
[2016-11-30 20:08:25] |
So you need to contact your broker and have them authorize your CQG account for real-time CME data. Once they do that follow the instructions here to reconnect to the data feed: http://www.sierrachart.com/index.php?page=doc/FileMenu.html#ProcedureToReconnect And then you will need to re-download the data in the chart with Edit >> Delete All Data and Download to remove the out of order data which was caused by the delayed data you are currently receiving. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-30 20:09:04
