Date/Time: Sat, 05 Sep 2026 17:16:09 +0000
Blank Charts
View Count: 1161
[2016-11-23 14:59:56]
User636679 - Posts: 32
Trying to use SC Data, pursuant your recommendation. Only Symbol that loads is ES. No other symbols load. Please advise asap.
Thank you,
Bryan
[2016-11-23 15:16:32]
Provide a copy of the Message Log by following these instructions:
https://www.sierrachart.com/index.php?l=doc/PostingInformation.php#MessageLog
[2016-11-23 15:43:10]
Reading Internal Order ID file. | 2016-11-23 08:41:43
Reading Trade Orders file. | 2016-11-23 08:41:43
Reading Trade Positions file. | 2016-11-23 08:41:43
Software version: 1483 | 2016-11-23 08:41:43
Uses New Spreadsheets | 2016-11-23 08:41:43
Usage end date: 2017-01-03 | 2016-11-23 08:41:43
Enabled for: Advanced Features. | 2016-11-23 08:41:43
Enabled for: Advanced Features 2. | 2016-11-23 08:41:43
Enabled for: Sierra Chart Historical Data Service. | 2016-11-23 08:41:43
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2016-11-23 08:41:43
Enabled for: INDEXES_DATA_BARCHART | 2016-11-23 08:41:43
Received 1 data feed usernames. | 2016-11-23 08:41:43
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-11-23 08:41:43
Current selected Data/Trading service: SC Forex Data (FXCM) | 2016-11-23 08:41:43
Chart Update Interval: 500 | 2016-11-23 08:41:43
Time Zone: -07:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-11-23 08:41:43
2016-11-23 08:41:46 Local computer time | 2016-11-23 08:41:43
2016-11-23 15:41:46 Local computer time in UTC | 2016-11-23 08:41:43
2016-11-23 08:41:46 Local computer time in SC Time Zone | 2016-11-23 08:41:43
2016-11-23 15:41:46 Server time in UTC | 2016-11-23 08:41:43
Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-11-23 08:41:43
Program path: C:\SierraChart\ | 2016-11-23 08:41:43
Data Files path: C:\SierraChart\Data\ | 2016-11-23 08:41:43
OS Version Number: 6.2 | 2016-11-23 08:41:43
Locale Setting: C | 2016-11-23 08:41:43
Checking for new symbol settings for fxcm | 2016-11-23 08:41:43
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-11-23 08:41:43
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-11-23 08:41:43
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-11-23 08:41:43
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-11-23 08:41:47
Symbol settings are up-to-date for fxcm | 2016-11-23 08:41:47
SC Forex Data (FXCM) | Connected to data server. | 2016-11-23 08:41:51
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-11-23 08:41:52
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-11-23 08:41:52
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-11-23 08:41:52
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-11-23 08:41:52
QCLF17 [CBV] #1 | Reloading chart. | 2016-11-23 08:41:58
QCLF17 [CBV] #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2016-11-23 08:41:58
QCLF17 [CBV] #1 | There are no continuous futures contract symbols. Loading data normally. | 2016-11-23 08:41:58
QCLF17 [CBV] #7 | Reloading chart. | 2016-11-23 08:41:58
QCLF17 [CBV] #7 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2016-11-23 08:41:58
QCLF17 [CBV] #7 | There are no continuous futures contract symbols. Loading data normally. | 2016-11-23 08:41:58
@ESZ16 [CBV] #10 | Reloading chart. | 2016-11-23 08:41:58
@ESZ16 [CBV] #10 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2016-11-23 08:41:58
@ESZ16 [CBV] #10 | There are no continuous futures contract symbols. Loading data normally. | 2016-11-23 08:41:58
JTNT.Z 1 Min #11 | Reloading chart. | 2016-11-23 08:41:58
QCLF17 [CBV] #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-08 12:29:00. Next Bar Date Time: 2016-08-08 06:30:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
@ESZ16 [CBV] Point & Figure 1-3 #2 | Reloading chart. | 2016-11-23 08:41:58
@ESZ16 [CBV] Point & Figure 1-3 #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2016-11-23 08:41:58
QCLF17 [CBV] #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-09 12:30:00. Next Bar Date Time: 2016-08-09 06:30:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
@ESZ16 [CBV] Point & Figure 1-3 #2 | There are no continuous futures contract symbols. Loading data normally. | 2016-11-23 08:41:58
QCLF17 [CBV] #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-10 12:33:00. Next Bar Date Time: 2016-08-10 06:34:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-11 12:33:00. Next Bar Date Time: 2016-08-11 06:34:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-12 12:32:00. Next Bar Date Time: 2016-08-12 06:32:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-15 12:32:00. Next Bar Date Time: 2016-08-15 06:32:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-16 12:33:00. Next Bar Date Time: 2016-08-16 06:34:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-17 12:34:00. Next Bar Date Time: 2016-08-17 06:34:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 Flex Renko 6-2-2 #3 | Reloading chart. | 2016-11-23 08:41:58
QCLF17 [CBV] #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-18 12:31:00. Next Bar Date Time: 2016-08-18 06:32:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-19 12:31:00. Next Bar Date Time: 2016-08-19 06:32:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-08 12:29:01. Next Bar Date Time: 2016-08-08 06:30:01. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-09 12:30:01. Next Bar Date Time: 2016-08-09 06:30:01. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-10 12:33:01. Next Bar Date Time: 2016-08-10 06:34:01. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-11 12:33:01. Next Bar Date Time: 2016-08-11 06:34:01. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-12 12:32:01. Next Bar Date Time: 2016-08-12 06:32:01. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 60 Min #4 | Reloading chart. | 2016-11-23 08:41:58
QCLF17 [CBV] #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-15 12:32:01. Next Bar Date Time: 2016-08-15 06:32:01. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-16 12:33:01. Next Bar Date Time: 2016-08-16 06:34:01. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-17 12:34:01. Next Bar Date Time: 2016-08-17 06:34:01. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-18 12:31:01. Next Bar Date Time: 2016-08-18 06:32:01. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-19 12:31:01. Next Bar Date Time: 2016-08-19 06:32:01. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 Flex Renko 6-2-2 #5 | Reloading chart. | 2016-11-23 08:41:58
QCLF17 60 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-08 12:00:00. Next Bar Date Time: 2016-08-08 06:00:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 60 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-09 12:00:00. Next Bar Date Time: 2016-08-09 06:00:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 60 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-10 12:00:00. Next Bar Date Time: 2016-08-10 06:00:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 60 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-11 12:00:00. Next Bar Date Time: 2016-08-11 06:00:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 60 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-12 12:00:00. Next Bar Date Time: 2016-08-12 06:00:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 60 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-15 12:00:00. Next Bar Date Time: 2016-08-15 06:00:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 60 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-16 12:00:00. Next Bar Date Time: 2016-08-16 06:00:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 60 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-17 12:00:00. Next Bar Date Time: 2016-08-17 06:00:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 60 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-18 12:00:00. Next Bar Date Time: 2016-08-18 06:00:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 60 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-19 12:00:00. Next Bar Date Time: 2016-08-19 06:00:00. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 Flex Renko 6-2-2 #5 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-08 12:27:53. Next Bar Date Time: 2016-08-08 06:30:46. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 Flex Renko 6-2-2 #5 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-09 12:30:05. Next Bar Date Time: 2016-08-09 06:30:43. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 Flex Renko 6-2-2 #5 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-10 12:33:23. Next Bar Date Time: 2016-08-10 06:34:34. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 Flex Renko 6-2-2 #5 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-11 12:30:56. Next Bar Date Time: 2016-08-11 06:34:33. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 Flex Renko 6-2-2 #5 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-12 12:29:05. Next Bar Date Time: 2016-08-12 06:32:19. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 Flex Renko 6-2-2 #5 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-15 12:32:01. Next Bar Date Time: 2016-08-15 06:32:10. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 Flex Renko 6-2-2 #5 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-16 12:31:39. Next Bar Date Time: 2016-08-16 06:34:09. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 Flex Renko 6-2-2 #5 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-17 12:30:08. Next Bar Date Time: 2016-08-17 06:34:20. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 Flex Renko 6-2-2 #5 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-18 12:30:34. Next Bar Date Time: 2016-08-18 06:32:13. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 Flex Renko 6-2-2 #5 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-19 12:29:07. Next Bar Date Time: 2016-08-19 06:32:15. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] Point & Figure 1-3 #6 | Reloading chart. | 2016-11-23 08:41:58
QCLF17 [CBV] Point & Figure 1-3 #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2016-11-23 08:41:58
QCLF17 [CBV] Point & Figure 1-3 #6 | There are no continuous futures contract symbols. Loading data normally. | 2016-11-23 08:41:58
QCLF17 [CBV] Point & Figure 1-3 #6 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-08 06:51:34. Next Bar Date Time: 2016-08-08 06:30:46. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] Point & Figure 1-3 #6 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-09 06:59:49. Next Bar Date Time: 2016-08-09 06:30:43. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] Point & Figure 1-3 #6 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-10 06:58:12. Next Bar Date Time: 2016-08-10 06:34:34. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] Point & Figure 1-3 #6 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-11 06:57:23. Next Bar Date Time: 2016-08-11 06:34:33. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] Point & Figure 1-3 #6 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-12 06:59:41. Next Bar Date Time: 2016-08-12 06:32:19. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] Point & Figure 1-3 #6 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-15 06:56:21. Next Bar Date Time: 2016-08-15 06:32:10. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] Point & Figure 1-3 #6 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-16 06:59:44. Next Bar Date Time: 2016-08-16 06:34:09. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] Point & Figure 1-3 #6 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-17 06:55:40. Next Bar Date Time: 2016-08-17 06:34:20. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] Point & Figure 1-3 #6 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-18 07:00:00. Next Bar Date Time: 2016-08-18 06:32:13. Filename: QCLF17.scid | 2016-11-23 08:41:58
QCLF17 [CBV] Point & Figure 1-3 #6 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-08-19 06:59:57. Next Bar Date Time: 2016-08-19 06:32:15. Filename: QCLF17.scid | 2016-11-23 08:41:58
CLF17 [CBV] Point & Figure 1-3 #8 | Reloading chart. | 2016-11-23 08:41:58
CLF17 [CBV] Point & Figure 1-3 #8 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2016-11-23 08:41:58
CLF17 [CBV] Point & Figure 1-3 #8 | There are no continuous futures contract symbols. Loading data normally. | 2016-11-23 08:41:58
CLF17 [CBV] Point & Figure 1-3 #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLF17.scid | 2016-11-23 08:41:58
SC Forex Data (FXCM) | Starting real-time market data updates for: QCLF17. ID: 1 | 2016-11-23 08:41:58
SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: QCLF17 | 2016-11-23 08:41:58
SC Forex Data (FXCM) | Requesting security definition data for: QCLF17. ID: 1 | 2016-11-23 08:41:58
Intraday data recording state for symbol QCLF17 is set to download 'Pending'. | 2016-11-23 08:41:58
Delaying start of download for QCLF17 | 2016-11-23 08:41:58
SC Forex Data (FXCM) | Starting real-time market data updates for: JTNT.Z. ID: 2 | 2016-11-23 08:41:58
SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: JTNT.Z | 2016-11-23 08:41:58
SC Forex Data (FXCM) | Requesting security definition data for: JTNT.Z. ID: 2 | 2016-11-23 08:41:58
Intraday data recording state for symbol JTNT.Z is set to download 'Pending'. | 2016-11-23 08:41:58
HD Request # 2 | Downloading Intraday chart data for QCLF17 to the file QCLF17.scid. Service: fxcm | 2016-11-23 08:41:58
HD Request # 2 | Download start date-time: 2016-11-23 08:41:09.000 | 2016-11-23 08:41:58
HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2016-11-23 08:41:58
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-11-23 08:41:58
SC Forex Data (FXCM) | Starting real-time market data updates for: @ESZ16. ID: 3 | 2016-11-23 08:41:58
SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: @ESZ16 | 2016-11-23 08:41:58
SC Forex Data (FXCM) | Requesting security definition data for: @ESZ16. ID: 3 | 2016-11-23 08:41:58
Intraday data recording state for symbol @ESZ16 is set to download 'Pending'. | 2016-11-23 08:41:58
Socket (4) | Connected. | 2016-11-23 08:41:58
HD Request # 2 | Setting DTC encoding to Binary VLS | 2016-11-23 08:41:58
HD Request # 2 | Sending historical data logon request message. | 2016-11-23 08:41:58
SC Forex Data (FXCM) | Starting real-time market data updates for: CLF17. ID: 4 | 2016-11-23 08:41:59
SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: CLF17 | 2016-11-23 08:41:59
SC Forex Data (FXCM) | Requesting security definition data for: CLF17. ID: 4 | 2016-11-23 08:41:59
Intraday data recording state for symbol CLF17 is set to download 'Pending'. | 2016-11-23 08:41:59
HD Request # 2 | Requesting Intraday data. Start date-time: 2016-11-23 08:41:09. Record interval: 0. Symbol: QCLF17 | 2016-11-23 08:41:59
HD Request # 2 | Error downloading historical Intraday data for QCLF17. Historical data file not available for symbol. | 2016-11-23 08:41:59
Socket (4) | Shutdown and closed. | 2016-11-23 08:41:59
The network socket for historical data has been closed. | 2016-11-23 08:41:59
HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for QCLF17 | 2016-11-23 08:41:59
HD Request # 2 | Intraday download COMPLETE for QCLF17. Completion time: 0s. Unique request ID: 1 | 2016-11-23 08:41:59
Removed historical data download ID 1 | 2016-11-23 08:41:59
Real-time Intraday chart data file updates started for QCLF17 | 2016-11-23 08:41:59
Intraday chart data file opened for QCLF17 | 2016-11-23 08:41:59
Delaying start of download for JTNT.Z | 2016-11-23 08:41:59
HD Request # 3 | Downloading Intraday chart data for JTNT.Z to the file JTNT.Z.scid. Service: equities.us | 2016-11-23 08:42:04
HD Request # 3 | Download start date-time: 2016-11-23 08:41:09.000 | 2016-11-23 08:42:04
HD Request # 3 | Using server: ds3.sierracharts.com port 10149 | 2016-11-23 08:42:04
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-11-23 08:42:04
Socket (5) | Connected. | 2016-11-23 08:42:04
HD Request # 3 | Setting DTC encoding to Binary VLS | 2016-11-23 08:42:04
HD Request # 3 | Sending historical data logon request message. | 2016-11-23 08:42:04
HD Request # 3 | Error downloading historical Intraday data for JTNT.Z. Historical data logon error: Invalid/missing data for service code: equities.us | 2016-11-23 08:42:04
Socket (5) | Shutdown and closed. | 2016-11-23 08:42:04
The network socket for historical data has been closed. | 2016-11-23 08:42:04
HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for JTNT.Z | 2016-11-23 08:42:04
HD Request # 3 | Intraday download COMPLETE for JTNT.Z. Completion time: 0s. Unique request ID: 2 | 2016-11-23 08:42:04
Removed historical data download ID 2 | 2016-11-23 08:42:04
Real-time Intraday chart data file updates started for JTNT.Z | 2016-11-23 08:42:04
Intraday chart data file opened for JTNT.Z | 2016-11-23 08:42:04
HD Request # 4 | Downloading Intraday chart data for @ESZ16 to the file @ESZ16.scid. Service: fxcm | 2016-11-23 08:42:04
HD Request # 4 | Download start date-time: 2016-11-23 08:41:09.000 | 2016-11-23 08:42:04
HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2016-11-23 08:42:04
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-11-23 08:42:04
Socket (6) | Connected. | 2016-11-23 08:42:04
HD Request # 4 | Setting DTC encoding to Binary VLS | 2016-11-23 08:42:04
HD Request # 4 | Sending historical data logon request message. | 2016-11-23 08:42:04
HD Request # 4 | Requesting Intraday data. Start date-time: 2016-11-23 08:41:09. Record interval: 0. Symbol: @ESZ16 | 2016-11-23 08:42:04
HD Request # 4 | Error downloading historical Intraday data for @ESZ16. Historical data file not available for symbol. | 2016-11-23 08:42:04
Socket (6) | Shutdown and closed. | 2016-11-23 08:42:04
HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for @ESZ16 | 2016-11-23 08:42:04
HD Request # 4 | Intraday download COMPLETE for @ESZ16. Completion time: 0s. Unique request ID: 3 | 2016-11-23 08:42:04
Removed historical data download ID 3 | 2016-11-23 08:42:04
Real-time Intraday chart data file updates started for @ESZ16 | 2016-11-23 08:42:04
Intraday chart data file opened for @ESZ16 | 2016-11-23 08:42:04
HD Request # 5 | Downloading Intraday chart data for CLF17 to the file CLF17.scid. Service: fxcm | 2016-11-23 08:42:04
HD Request # 5 | Download start date-time: 2015-11-24 08:42:04.000 | 2016-11-23 08:42:04
HD Request # 5 | Using server: ds3.sierracharts.com port 10149 | 2016-11-23 08:42:04
Socket (7) | Connected. | 2016-11-23 08:42:04
HD Request # 5 | Setting DTC encoding to Binary VLS | 2016-11-23 08:42:04
HD Request # 5 | Sending historical data logon request message. | 2016-11-23 08:42:04
HD Request # 5 | Requesting Intraday data. Start date-time: 2015-11-24 08:42:04. Record interval: 0. Symbol: CLF17 | 2016-11-23 08:42:05
HD Request # 5 | Error downloading historical Intraday data for CLF17. Historical data file not available for symbol. | 2016-11-23 08:42:05
Socket (7) | Shutdown and closed. | 2016-11-23 08:42:05
The network socket for historical data has been closed. | 2016-11-23 08:42:05
HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLF17 | 2016-11-23 08:42:05
HD Request # 5 | Intraday download COMPLETE for CLF17. Completion time: 1s. Unique request ID: 4 | 2016-11-23 08:42:05
Removed historical data download ID 4 | 2016-11-23 08:42:05
Real-time Intraday chart data file updates started for CLF17 | 2016-11-23 08:42:05
Intraday chart data file opened for CLF17 | 2016-11-23 08:42:05
[2016-11-23 18:06:20]
There are two problems.
You did not follow step number 15 here:
http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
The Service needs to be SC Data - All Services.
And you need to use the symbols listed in File >> Find Symbol:
http://www.sierrachart.com/index.php?page=doc/helpdetails1.php#h1.3
