Date/Time: Fri, 13 Mar 2026 21:08:34 +0000
Cannot connect to the trade service
View Count: 1011
[2016-08-17 03:44:37]
User299392 - Posts: 216
Log attached -
Reading Internal Order ID file. | 2016-08-16 23:42:24
Reading Trade Orders file. | 2016-08-16 23:42:24
Reading Trade Positions file. | 2016-08-16 23:42:24
Software version: 1453 | 2016-08-16 23:42:24
Uses New Spreadsheets | 2016-08-16 23:42:24
Enabled for: Advanced Features. | 2016-08-16 23:42:24
Enabled for: Advanced Features 2. | 2016-08-16 23:42:24
Enabled for: Sierra Chart Historical Data Service. | 2016-08-16 23:42:24
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-08-16 23:42:24
Current selected Data/Trading service: CQG FIX Trading | 2016-08-16 23:42:24
Chart Update Interval: 700 | 2016-08-16 23:42:24
Data/Trade Service Settings automatically set. | 2016-08-16 23:42:24
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-08-16 23:42:24
2016-08-16 23:42:27 Local computer time | 2016-08-16 23:42:24
2016-08-17 03:42:27 Local computer time in UTC | 2016-08-16 23:42:24
2016-08-16 23:42:27 Local computer time in SC Time Zone | 2016-08-16 23:42:24
2016-08-17 03:42:21 Server time in UTC | 2016-08-16 23:42:24
Local computer UTC time and Server UTC time difference: 6 seconds. | 2016-08-16 23:42:24
Program path: C:\SierraChart\ | 2016-08-16 23:42:24
Data Files path: C:\SierraChart\Data\ | 2016-08-16 23:42:24
OS Version Number: 6.2 | 2016-08-16 23:42:24
Locale Setting: C | 2016-08-16 23:42:24
Created the DTC Protocol server. | 2016-08-16 23:42:24
DTC Protocol Server listening on port 11099. | 2016-08-16 23:42:24
Created the DTC Protocol historical data server. | 2016-08-16 23:42:24
HD Server Manager | Listening on port 11098 | 2016-08-16 23:42:24
Checking for new symbol settings for cqg | 2016-08-16 23:42:24
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-08-16 23:42:24
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-08-16 23:42:24
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-08-16 23:42:24
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-08-16 23:42:24
Symbol settings are up-to-date for cqg | 2016-08-16 23:42:28
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-08-16 23:42:32
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-08-16 23:42:32
socket (4) | Connected. | 2016-08-16 23:42:33
socket (4) | Starting TLS 1.2 connection. | 2016-08-16 23:42:33
socket (4) | SSL connection established. | 2016-08-16 23:42:33
CQG FIX: Sending the Logon message. | 2016-08-16 23:42:33
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-08-16 23:42:33
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-08-16 23:42:33
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-08-16 23:42:33
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-08-16 23:42:33
socket (4) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-08-16 23:42:34
socket (4) | SSL shutdown indicates not able to send 'close notify'. | 2016-08-16 23:42:34
socket (4) | SSL has been shut down. | 2016-08-16 23:42:34
socket (4) | SSL object has been freed. SSL state is now disconnected. | 2016-08-16 23:42:34
socket (4) | Shutdown and closed. | 2016-08-16 23:42:34
CQG FIX: Socket connection was closed without any logout messages sent or received. | 2016-08-16 23:42:34
CQG FIX: Disconnected. | 2016-08-16 23:42:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-08-16 23:42:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-08-16 23:42:34
CQG FIX Trading | Disconnected. | 2016-08-16 23:42:34
The above has been sent to support. | 2016-08-16 23:43:17 *
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-08-16 23:43:17
HTTP connection to www.sierrachart.com:80 (5) | Connected. | 2016-08-16 23:43:17
Sending of the message log was completed. Please read the response that was received. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2016-08-16 23:43:18
HTTP connection to www.sierrachart.com:80 (5) | Closed. No error. | 2016-08-16 23:43:22
HTTP connection to www.sierrachart.com:80 (5) | Shutdown and closed. | 2016-08-16 23:43:22
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-08-16 23:43:50
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-08-16 23:43:50
socket (6) | Connected. | 2016-08-16 23:43:50
socket (6) | Starting TLS 1.2 connection. | 2016-08-16 23:43:50
socket (6) | SSL connection established. | 2016-08-16 23:43:50
CQG FIX: Sending the Logon message. | 2016-08-16 23:43:50
socket (6) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-08-16 23:43:51
socket (6) | SSL shutdown indicates not able to send 'close notify'. | 2016-08-16 23:43:51
socket (6) | SSL has been shut down. | 2016-08-16 23:43:51
socket (6) | SSL object has been freed. SSL state is now disconnected. | 2016-08-16 23:43:51
socket (6) | Shutdown and closed. | 2016-08-16 23:43:51
CQG FIX: Socket connection was closed without any logout messages sent or received. | 2016-08-16 23:43:51
CQG FIX: Disconnected. | 2016-08-16 23:43:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-08-16 23:43:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-08-16 23:43:51
CQG FIX Trading | Disconnected. | 2016-08-16 23:43:51
[2016-08-17 04:01:20]
PLEASE HELP!
[2016-08-17 04:01:53]
I have also tried connecting after the installation of the latest download update available but in vain.
[2016-08-17 04:40:38]
You are having trouble connecting to CQG and CQG had a server problem earlier this evening.
This is not anything that we have control over in any way.
