Date/Time: Fri, 13 Mar 2026 20:47:22 +0000
TranAct Datafeed Question
View Count: 1387
[2016-08-16 01:24:26]
User488039 - Posts: 114
I just have a quick question regarding TransAct.
I noticed that a TransAct file TransactToSierraBridge.exe is invoked from the sierrachart/transact folder. Can someone tell me is this necessary for a regular Sierra Chart subscription, when not using TransACt AT?
I'm trying to figure out if the SierraChart\Transact folder comes with SierraChart by default, or if it was put there from installing TransAct AT, which I am not using?
Thank you
[2016-08-16 03:16:50]
The files in the TransAct folder are only used when connecting to TransAct. Otherwise, they are not needed.
Date Time Of Last Edit: 2016-08-16 03:17:09
[2016-08-16 05:23:01]
Thank you for getting back with me on this. What I'm asking is, was that TransAct subdirectory put there when TransAct AT was installed (which I'm not using at all anymore - I'm using a SierraChart subscription), or is the TransAct subdirectory there when SierraChart is installed?
Thanks again
[2016-08-16 05:34:20]
That folder is installed with Sierra Chart whether you use TransAct or not. You can safely delete it if you do not want it.
[2016-08-16 06:01:29]
Thank you very much.
