Date/Time: Fri, 13 Mar 2026 19:43:09 +0000
Header File Help Needed
View Count: 1628
| [2016-08-02 05:26:48] |
| User147461 - Posts: 33 |
Newbie from TS and MC to Sierra Chart. Trying to learn SC basics to start converting my code. My thoughts are to create 3 files for my SC code: MyStudies.cpp MyFunctions.cpp MyFunctions.h I'm having a problem compiling, getting this error: C:\WINDOWS\cc7SbtVs.o:examplestudy.cpp:(.text+0x51): undefined reference to `ExampleFunction_S(float, float, float)'collect2.exe: error: ld returned 1 exit status If I change the #include statement from "examplefunction.h" to "examplefunction.cpp" the error goes away and compiles fine. I think the function prototype in my header file needs additional code, but I don't know for sure. My code is below. All suggestions and thoughts are welcomed. Thank you for helping me get started! //#include "examplefunction.h" // C:\WINDOWS\cc7SbtVs.o:examplestudy.cpp:(.text+0x51): undefined reference to `ExampleFunction_S(float, float, float)'collect2.exe: error: ld returned 1 exit status #include "examplefunction.cpp" #include "sierrachart.h" SCDLLName("examplestudy") SCSFExport scsf_ExampleStudy(SCStudyInterfaceRef sc) { if (sc.SetDefaults) { sc.GraphName = "Example Study"; sc.GraphRegion = 1; //During development set this flag to 1, so the DLL can be modified. When development is completed, set it to 0 to improve performance. sc.FreeDLL = 1; sc.Subgraph[0].Name = "Function Return Value"; sc.Subgraph[0].DrawStyle = DRAWSTYLE_LINE; sc.Subgraph[0].LineWidth = 4; sc.Subgraph[0].PrimaryColor = RGB(255,0,0); sc.AutoLoop = 1; return; } float FunctionValue; FunctionValue = ExampleFunction_S(100.25, 200.50, 300.75); // 601.5 sc.Subgraph[0][sc.Index] = FunctionValue; return; } #include "examplefunction.h" #include "sierrachart.h" /***************************************************************************** User note: The functions in this file are intermediate level functions you can copy and call from your primary scsf_ functions. These functions are not complete study functions, but are used by primary study functions to perform calculations. Where you see _S at the end, this means that the function is a single step function, and only fills in the array element at Index. *****************************************************************************/ float ExampleFunction_S(float a, float b, float c) { float r; r=a+b+c; return (r); } // examplefunction.h file float ExampleFunction_S(float a, float b, float c); |
| [2016-08-02 15:28:46] |
You are going to make things much easier for yourself by putting all of the code into a single source code file. And including this line just above the study function where it is called from: float ExampleFunction_S(float a, float b, float c); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
