Date/Time: Fri, 13 Mar 2026 20:27:29 +0000
Chart
View Count: 879
| [2016-08-01 19:46:34] |
| User39772 - Posts: 311 |
Hello, via the chart setiings dialog I can select "line on close". Would it be possible to also configure line on high, line on low or to make two different lines visible at the same time ? When I select Renko with wicks it switches to candle stick bars. I do not see heikin ashi charts. Is there a reason for it ? |
| [2016-08-02 04:59:19] |
For the available Graph Draw Types, refer to: Graph Draw Types You may also be interested in this study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s100 For Renko bars, refer to: Renko Bar Charts For Heikin-Ashi bars, refer to: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s138 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
