Date/Time: Fri, 13 Mar 2026 21:06:44 +0000
time range highlight
View Count: 1933
| [2016-07-31 21:42:06] |
| User705641 - Posts: 38 |
Hi I have used the time range highlight to mark certain trading times however I want a box area for the time frame with the top and bottom boundaries of the box reflecting the high and low for that particular time session. The box would be preferable to the whole block of colour on the screeen from the time range highlight. Is there any way of achieving this setup? |
| [2016-07-31 22:02:44] |
Yes, use this study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s246 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-31 22:03:02
| [2016-08-01 23:15:29] |
Thanks for the study - is there any way I can hide the bottom box so that all I see on screen is the top box reflecting the high and low levels?
| [2016-08-01 23:19:30] |
This is not clear for us. It should work like you intend. Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
