Date/Time: Thu, 12 Mar 2026 04:25:55 +0000
Numbers Bars - Diagonal Domiant Side
View Count: 2218
[2016-07-26 12:25:34]
User381102 - Posts: 7
could you please explain to me the color at the high of the profile at 09:00 o'clock.
I don't understand it.
Here is the chart
https://s31.postimg.org/ai0mm03jv/image.png
The top bar inhabits range 3 down color no matter if "diagonal zero bid/ask compares" is turned off or turned on.
Here are the settings
https://s31.postimg.org/3nq0bjnqj/image.png
[2016-07-26 12:27:30]
I'm referring to 70 x 85 bar at 09:00 being red color.
Date Time Of Last Edit: 2016-07-26 12:35:52
[2016-07-26 13:00:18]
If using just text coloring with otherwise same settings then it shows grey color if zero bid/ask compares is set to 'No'.
https://s32.postimg.org/qbm0yzfit/image.png
[2016-07-26 18:22:48]
We are checking on this.
[2016-08-02 05:51:30]
We have looked into this. When you are doing a diagonal comparison, Column # Background Type must be set to Background on Dominant Side. Otherwise, the coloring will not be logical.
