Date/Time: Thu, 12 Mar 2026 03:59:36 +0000
Pivot Points Variable Period - R4/S4 not populating
View Count: 2179
| [2016-06-23 09:48:08] |
| User299392 - Posts: 216 |
For the above study, R4/S4 pivots just won't show up. Please help! See images below - http://www.sierrachart.com/image.php?Image=1466675123856.png http://www.sierrachart.com/image.php?Image=1466675057838.png |
| [2016-06-23 18:17:18] |
What is the Formula Type input set to for the Pivot Points study?
| [2016-06-23 18:25:27] |
Formula Type = 8
| [2016-06-23 18:37:26] |
We do not know what the formula should be for support and resistance lines 4. According to our notes these are from www.shadowtrader.net. If you let us know what the formula is, we can add it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-23 18:55:29
| [2016-06-23 18:51:00] |
Thank you so much for your help. Let me know when done and I will try it out. See below for R4 / S4 - PIVOT = (High + Close + Low)/3 R4 = High + 3(Pivot – Low) R3 = High + 2(Pivot – Low) R2 = Pivot + (R1 – S1) R1 = (2*Pivot) – Low S1 = (2*Pivot) – High S2 = Pivot – (R1 – S1) S3 = Low – 2(Hi – Pivot) S4 = Low – 3(Hi – Pivot) |
| [2016-06-23 18:55:07] |
These additional levels will be supported in the next release.
| [2016-07-01 14:43:11] |
Another problem with the latest release over this issue - Now, 1. R2 does not show up for Formula Type 8. 2. The formula as passed to you earlier does not seem to match Formula Type = 8. Will appreciate if you can please check. Below is the shadow trader formula yet again - PIVOT = (High + Close + Low)/3 R4 = High + 3(Pivot – Low) R3 = High + 2(Pivot – Low) R2 = Pivot + (R1 – S1) R1 = (2*Pivot) – Low S1 = (2*Pivot) – High S2 = Pivot – (R1 – S1) S3 = Low – 2(Hi – Pivot) S4 = Low – 3(Hi – Pivot) |
| [2016-07-01 19:25:21] |
1. We see what the problem is. This will be solved in the next release. 2. We are checking the calculations again now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-07-13 17:22:03] |
This still does not work unless it was taken care of in 1444 release? Can you please confirm? |
| [2016-07-13 17:35:59] |
Not sure what version this was solved in. But definitely in 1444.
| [2016-07-13 23:45:02] |
So, I installed 1444 as well and the inconsistency remains. It works for ES, NQ and not for any other products like GC and CC????? |
| [2016-07-13 23:46:46] |
I meant it does not work for Gold, Crude and Natural Gas and the like.
| [2016-07-14 01:21:09] |
This is what we see for GC (Gold) August using formula type 8: http://www.sierrachart.com/image.php?Image=1468459224855.png We do not see any problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-07-14 01:29:11] |
See my file attached - same contract and not working with Pivot Points - Variable Period.
Attachment Deleted. |
| [2016-07-14 02:20:54] |
Set Auto Skip Period of No Trading to No. The documentation does explain this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-08-01 20:22:28] |
This is again acting up. Pivots will not calculate for GC futures product. Image shows the settings of this study. Please help! |
| [2016-08-01 20:58:47] |
Increase the Number of Days to Calculate input to see if they then appear. Also would be better if you use the Pivot Points-Daily study instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-08-01 21:30:59] |
Problem with Pivot Points - Daily is that formula # 8 is not programmed accurately(see above for this chat message exchanges). It appears that the changes were done just for PivotPoints-Variable Period and not for Pivot Points - Daily. Including the # 8 shadow trader type formula yet again below for you to update the Pivot Points-Daily study.- PIVOT = (High + Close + Low)/3 R4 = High + 3(Pivot – Low) R3 = High + 2(Pivot – Low) R2 = Pivot + (R1 – S1) R1 = (2*Pivot) – Low S1 = (2*Pivot) – High S2 = Pivot – (R1 – S1) S3 = Low – 2(Hi – Pivot) S4 = Low – 3(Hi – Pivot) Can you confirm this to be the case before I use the proposed study? |
| [2016-08-01 21:50:13] |
The formula is correct for both of the studies because they share the same formula.
| [2016-08-01 21:51:14] |
Ok; I will check again and on other products too.
