Date/Time: Sat, 14 Nov 2026 02:59:30 +0000
ACSIL - Chart Values - displaying - Integer values
View Count: 1838
| [2016-06-09 18:35:30] |
| ejtrader - Posts: 689 |
SC team - Generally sub-graph values gets stored as float values. Is there any way to display the "integer" values in Chart Values window? I am using standard study - scsf_BarNumbering - and in chart values it appears as decimal value. Wondering if there is any way to display just an integer values. As you see from attached image - Region 1 - has both integers & decimals (but they are built-in values). Trying to see if there is any way to make sub-graph values to be displayed as integers in Chart/Tool Values window. Thanks Date Time Of Last Edit: 2016-06-09 22:14:10
| [2016-06-10 10:00:53] |
Refer to: Changing the Price/Value Display Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-06-10 14:32:42] |
SC Team - Thank you for pointing this out. This certainly takes care of a study - which has single value to display. However if the study has multiple sub-graphs and wanted to have a combination of integers & non-integers - how to get that taken care? Was hoping there should be something like below would take care of it but this doesn't seem to be available. Any suggestion? sg[0].ValueFormat = 0; // integer sg[1].ValueFormat = 2; // non-integer with 2 decimals Thanks Date Time Of Last Edit: 2016-06-10 14:33:07
| [2016-06-10 19:23:57] |
There is only a single value format setting per study.
