Date/Time: Thu, 28 Mar 2024 21:30:46 +0000
[Locked] - SierraChart is showing closed positions as opened.
View Count: 3530
[2013-08-02 06:21:28] |
Please try Prerelease version 1003 and let us know if the problem is resolved.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-02 06:21:47
[2013-08-02 16:13:09] |
imdtrader - Posts: 26 |
Hello, I used version 1003 for my live trading today (6 trades) and everything was working fine - no error so far. Thank you. |
[2013-08-02 17:10:51] |
User83524 - Posts: 27 |
I upgraded TWS to 939.2 and SC to 1003. Everything seems to be working fine now after 18 sim trades. So far so good . . will keep testing. I've been having this problem for months as mentioned in prior posts . . maybe I can finally use SC for trades rather than TWS. I really appreciate you correcting this problem. Thanks!!!
[2013-08-02 20:55:38] |
This is good. Unless you have more than one Trade account on your Trader Workstation username, if you been having a problem where the position would disappear after about 8 seconds and you had entered the correct Positions Account number in Global Settings >>Data/Trade Service Settings (this was required in older versions of Sierra Chart) then this was indicating that TWS was not automatically sending the position data whenever it changes. When there are multiple trade accounts on a TWS username, there is a problem with this because Interactive Brokers will not send automatic position updates for more than one account, only a single account. So the solution is now we no longer start automatic position updates and manually request them upon every fill and upon connection to TWS. We should not have to do this. This really is something that Interactive Brokers needs to address. We do not have this problem with any other trading service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-13 20:26:06
[2013-08-12 17:34:11] |
I'm now having exactly the same prior problems. Still using SC 1003. Only happens when there are two separate trades at the same time. A single trade seems to work fine. (Three trades simultaneously also creates problems.) I'll try upgrading to SC 1004 and see if that helps. Date Time Of Last Edit: 2013-08-12 17:35:53
[2013-08-12 17:45:00] |
Yes please update to the very latest release of Sierra Chart. This problem should definitely be resolved.
[2013-08-13 18:58:55] |
I upgraded to SC 1007 . . still same problems when two separate trades operating simultaneously. Single trades seem to do fine. I seem to have the problems when running both trades thru the same window. Now testing with separate windows. Date Time Of Last Edit: 2013-08-13 19:29:05
[2013-08-13 19:12:51] |
Sierra Chart - Max - Posts: 5554 |
1009 is the latest stable release.
Sierra Chart Support |
[2013-08-13 19:49:56] |
Don't seem to have any problems using separate windows for simultaneous trades . . but only based on a handful of trades. I'll upgrade to SC 1009 . . Thanks, Max |
[2013-08-13 20:00:50] |
If you continue notice a problem start a new thread and describe precisely the problem you are having. We need to understand in your own words what problem you are having without reference to what someone else has said.
