Date/Time: Thu, 10 Sep 2026 06:52:57 +0000
[User Discussion] - large number formatting
View Count: 1141
| [2016-04-15 20:06:35] |
| User12089 - Posts: 386 |
The volume profile allows displaying the total volume of the profile as well as the volume in each horizontal bar of the profile However I could not discover an option for applying Large Number formatting to the displayed volume numbers Example - currently the volume is displayed as 4000000 while it is more convenient to see it as 4 mln another example is the ZZ study in Sierra which allows using Large Number formatting |
| [2016-04-18 19:12:00] |
We will add an option for this.
| [2017-01-28 18:44:26] |
the option doesn't seem to have been implemented yet
