Date/Time: Thu, 12 Mar 2026 04:20:44 +0000
separating out stop orders.
View Count: 1274
[2016-04-15 03:23:30]
kinghat - Posts: 120
on the chart trading when you have an attached order with multiple targets and a single common stop(http://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#UsingSingleCommonStop) i like that i can drag all of the stops from its position and move it to another. is it possible to have that same standard functionality but be able to pull one of the stop orders out and move it while leaving the rest where they were?
[2016-04-15 04:13:46]
The stop orders must be separate Attached Orders each in a separate OCO Group #. They cannot be set to All OCO Groups.
So this has to be done from the start before submitting the main order.
[2016-04-15 04:16:23]
if i do it that way it wont be possible to drag all of the stop orders that are at the same price initially as the default operation, correct? if i did it this way when i try to drag and move the stop orders it will only take one at a time?
[2016-04-15 05:15:41]
Yes. That is correct.
We will see about adding a command to break the link between the Stop orders. But we have to contemplate if there is any consequence to that.
[2016-08-02 14:09:13]
would there be any consequence to adding this?
[2016-08-02 15:11:15]
We are not sure yet. This is still on our list of things to do. Could be still months before we get to it.
