Date/Time: Thu, 14 May 2026 00:31:33 +0000
AlertSoundNumber is shifted by one
View Count: 1009
| [2016-01-13 18:45:21] |
| T29_Dev1 - Posts: 22 |
Hi, I guess you shifted indexes when you added "No Alert Sound" in the combobox with list of sounds. For playing a correct sound I have to write: sc.SetAlert(alert_id.GetAlertSoundNumber() - 1); v. 1354 update: in the doc - "0 means no alert sound" in fact it returns 1 for "no alert sound" and 0 for "Alert Disabled" Date Time Of Last Edit: 2016-01-13 18:50:23
| [2016-01-14 08:57:12] |
Thank you for pointing this out. We are updating the documentation now.
| [2016-01-14 19:19:28] |
it's good that you have updated the documentation, but what about code samples? For example in the doc: sc.PlaySound(HighAlert.GetAlertSoundNumber(),"New Daily High"); must be: sc.PlaySound(HighAlert.GetAlertSoundNumber() - 1,"New Daily High"); and studies in the ACS_Source folder? Just I use it in many studies and before I fix it in all my studies I want to be sure you will not change back this feature. |
| [2016-01-14 20:57:35] |
We are aware of the code examples and we will be updating those later today.
