Date/Time: Thu, 25 Apr 2024 09:46:26 +0000
Unable to load charts- Error Messages
View Count: 2197
[2013-03-27 20:05:53] |
User53364 - Posts: 2 |
For this trial subscription I am using Interactive Brokers. I receive the attached message when I try to obtain chart. I am also attaching my screen to Software version: 956 | 2013-03-27 13:05:53 Current Service Package: 5 | 2013-03-27 13:05:53 Usage end date: 2013-04-06 | 2013-03-27 13:05:53 Sierra Chart Historical Data Service is included. | 2013-03-27 13:05:53 Active service: IQFeed | 2013-03-27 13:05:53 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2013-03-27 13:05:53 2013-03-27 13:05:53 Local computer clock time | 2013-03-27 13:05:53 2013-03-27 17:05:53 GMT time | 2013-03-27 13:05:53 2013-03-27 13:05:53 Time zone adjusted time | 2013-03-27 13:05:53 Time difference to server time: 0 seconds. | 2013-03-27 13:05:53 Program path: C:\SierraChart\ | 2013-03-27 13:05:53 Data Files path: C:\SierraChart\Data\ | 2013-03-27 13:05:53 OS Version Number: 6.1 | 2013-03-27 13:05:53 IQ Feed: Connecting. | 2013-03-27 13:05:59 Starting DTN IQ Feed interface software. | 2013-03-27 13:05:59 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:05:59 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:05:59 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:05:59 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:05:59 IQ Feed: Fully disconnected. | 2013-03-27 13:05:59 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:05:59 IQ Feed: Connecting. | 2013-03-27 13:06:04 Starting DTN IQ Feed interface software. | 2013-03-27 13:06:04 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:06:04 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:06:04 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:06:04 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:06:04 IQ Feed: Fully disconnected. | 2013-03-27 13:06:04 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:06:04 IQ Feed: Connecting. | 2013-03-27 13:06:09 Starting DTN IQ Feed interface software. | 2013-03-27 13:06:09 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:06:09 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:06:09 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:06:09 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:06:09 IQ Feed: Fully disconnected. | 2013-03-27 13:06:09 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:06:09 IQ Feed: Connecting. | 2013-03-27 13:06:14 Starting DTN IQ Feed interface software. | 2013-03-27 13:06:14 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:06:14 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:06:14 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:06:14 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:06:14 IQ Feed: Fully disconnected. | 2013-03-27 13:06:14 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:06:14 IQ Feed: Connecting. | 2013-03-27 13:06:19 Starting DTN IQ Feed interface software. | 2013-03-27 13:06:19 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:06:19 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:06:19 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:06:19 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:06:19 IQ Feed: Fully disconnected. | 2013-03-27 13:06:19 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:06:19 IQ Feed: Connecting. | 2013-03-27 13:06:24 Starting DTN IQ Feed interface software. | 2013-03-27 13:06:24 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:06:24 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:06:24 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:06:24 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:06:24 IQ Feed: Fully disconnected. | 2013-03-27 13:06:25 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:06:25 IQ Feed: Connecting. | 2013-03-27 13:06:30 Starting DTN IQ Feed interface software. | 2013-03-27 13:06:30 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:06:30 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:06:30 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:06:30 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:06:30 IQ Feed: Fully disconnected. | 2013-03-27 13:06:30 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:06:30 IQ Feed: Connecting. | 2013-03-27 13:06:35 Starting DTN IQ Feed interface software. | 2013-03-27 13:06:35 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:06:35 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:06:35 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:06:35 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:06:35 IQ Feed: Fully disconnected. | 2013-03-27 13:06:35 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:06:35 IQ Feed: Connecting. | 2013-03-27 13:06:40 Starting DTN IQ Feed interface software. | 2013-03-27 13:06:40 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:06:40 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:06:40 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:06:40 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:06:40 IQ Feed: Fully disconnected. | 2013-03-27 13:06:40 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:06:40 IQ Feed: Connecting. | 2013-03-27 13:06:45 Starting DTN IQ Feed interface software. | 2013-03-27 13:06:45 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:06:45 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:06:45 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:06:45 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:06:45 IQ Feed: Fully disconnected. | 2013-03-27 13:06:45 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:06:45 IQ Feed: Connecting. | 2013-03-27 13:06:50 Starting DTN IQ Feed interface software. | 2013-03-27 13:06:50 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:06:50 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:06:50 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:06:50 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:06:50 IQ Feed: Fully disconnected. | 2013-03-27 13:06:50 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:06:50 IQ Feed: Connecting. | 2013-03-27 13:06:55 Starting DTN IQ Feed interface software. | 2013-03-27 13:06:55 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:06:55 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:06:55 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:06:55 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:06:55 IQ Feed: Fully disconnected. | 2013-03-27 13:06:55 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:06:55 IQ Feed: Connecting. | 2013-03-27 13:07:00 Starting DTN IQ Feed interface software. | 2013-03-27 13:07:00 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:07:00 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:07:00 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:07:00 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:07:00 IQ Feed: Fully disconnected. | 2013-03-27 13:07:00 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:07:00 IQ Feed: Connecting. | 2013-03-27 13:07:05 Starting DTN IQ Feed interface software. | 2013-03-27 13:07:05 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:07:05 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:07:05 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:07:05 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:07:05 IQ Feed: Fully disconnected. | 2013-03-27 13:07:05 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:07:05 IQ Feed: Connecting. | 2013-03-27 13:07:10 Starting DTN IQ Feed interface software. | 2013-03-27 13:07:10 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:07:10 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:07:10 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:07:10 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:07:10 IQ Feed: Fully disconnected. | 2013-03-27 13:07:10 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:07:10 IQ Feed: Connecting. | 2013-03-27 13:07:15 Starting DTN IQ Feed interface software. | 2013-03-27 13:07:15 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:07:15 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:07:15 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:07:15 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:07:15 IQ Feed: Fully disconnected. | 2013-03-27 13:07:15 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:07:15 IQ Feed: Connecting. | 2013-03-27 13:07:20 Starting DTN IQ Feed interface software. | 2013-03-27 13:07:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:07:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:07:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:07:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:07:20 IQ Feed: Fully disconnected. | 2013-03-27 13:07:20 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:07:20 IQ Feed: Connecting. | 2013-03-27 13:07:25 Starting DTN IQ Feed interface software. | 2013-03-27 13:07:25 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:07:25 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:07:25 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:07:25 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:07:25 IQ Feed: Fully disconnected. | 2013-03-27 13:07:25 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:07:25 IQ Feed: Connecting. | 2013-03-27 13:07:30 Starting DTN IQ Feed interface software. | 2013-03-27 13:07:30 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:07:30 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:07:30 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:07:30 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:07:30 IQ Feed: Fully disconnected. | 2013-03-27 13:07:30 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:07:30 IQ Feed: Connecting. | 2013-03-27 13:07:35 Starting DTN IQ Feed interface software. | 2013-03-27 13:07:35 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:07:35 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:07:35 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:07:35 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:07:35 IQ Feed: Fully disconnected. | 2013-03-27 13:07:35 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:07:35 IQ Feed: Connecting. | 2013-03-27 13:07:40 Starting DTN IQ Feed interface software. | 2013-03-27 13:07:40 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:07:40 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:07:40 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:07:40 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:07:40 IQ Feed: Fully disconnected. | 2013-03-27 13:07:40 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:07:40 IQ Feed: Connecting. | 2013-03-27 13:07:45 Starting DTN IQ Feed interface software. | 2013-03-27 13:07:45 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:07:45 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:07:45 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:07:45 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:07:45 IQ Feed: Fully disconnected. | 2013-03-27 13:07:45 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:07:45 IQ Feed: Connecting. | 2013-03-27 13:07:50 Starting DTN IQ Feed interface software. | 2013-03-27 13:07:50 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:07:50 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:07:50 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:07:50 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:07:50 IQ Feed: Fully disconnected. | 2013-03-27 13:07:50 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:07:50 IQ Feed: Connecting. | 2013-03-27 13:07:51 Starting DTN IQ Feed interface software. | 2013-03-27 13:07:51 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:07:51 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:07:51 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:07:51 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:07:51 IQ Feed: Fully disconnected. | 2013-03-27 13:07:51 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:07:51 IQ Feed: Connecting. | 2013-03-27 13:07:56 Starting DTN IQ Feed interface software. | 2013-03-27 13:07:56 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:07:56 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:07:56 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:07:56 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:07:56 IQ Feed: Fully disconnected. | 2013-03-27 13:07:56 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:07:56 IQ Feed: Connecting. | 2013-03-27 13:08:01 Starting DTN IQ Feed interface software. | 2013-03-27 13:08:01 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:08:01 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:08:01 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:08:01 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:08:01 IQ Feed: Fully disconnected. | 2013-03-27 13:08:01 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:08:01 IQ Feed: Connecting. | 2013-03-27 13:08:04 Starting DTN IQ Feed interface software. | 2013-03-27 13:08:04 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:08:04 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:08:04 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:08:04 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:08:04 IQ Feed: Fully disconnected. | 2013-03-27 13:08:04 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:08:04 IQ Feed: Connecting. | 2013-03-27 13:08:09 Starting DTN IQ Feed interface software. | 2013-03-27 13:08:09 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:08:09 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:08:09 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:08:09 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:08:09 IQ Feed: Fully disconnected. | 2013-03-27 13:08:09 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:08:09 IQ Feed: Connecting. | 2013-03-27 13:08:14 Starting DTN IQ Feed interface software. | 2013-03-27 13:08:14 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:08:14 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:08:14 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:08:14 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:08:14 IQ Feed: Fully disconnected. | 2013-03-27 13:08:14 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:08:14 IQ Feed: Connecting. | 2013-03-27 13:08:19 Starting DTN IQ Feed interface software. | 2013-03-27 13:08:19 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:08:19 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:08:19 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:08:19 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:08:19 IQ Feed: Fully disconnected. | 2013-03-27 13:08:19 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:08:19 IQ Feed: Connecting. | 2013-03-27 13:11:19 Starting DTN IQ Feed interface software. | 2013-03-27 13:11:19 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:11:19 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:11:19 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:11:19 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:11:19 IQ Feed: Fully disconnected. | 2013-03-27 13:11:19 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:11:19 IQ Feed: Connecting. | 2013-03-27 13:14:19 Starting DTN IQ Feed interface software. | 2013-03-27 13:14:19 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:14:19 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:14:19 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:14:19 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:14:19 IQ Feed: Fully disconnected. | 2013-03-27 13:14:19 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:14:19 IQ Feed: Connecting. | 2013-03-27 13:17:19 Starting DTN IQ Feed interface software. | 2013-03-27 13:17:19 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:17:19 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:17:19 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:17:19 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:17:19 IQ Feed: Fully disconnected. | 2013-03-27 13:17:19 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:17:19 IQ Feed: Connecting. | 2013-03-27 13:20:20 Starting DTN IQ Feed interface software. | 2013-03-27 13:20:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:20:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:20:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:20:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:20:20 IQ Feed: Fully disconnected. | 2013-03-27 13:20:20 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:20:20 IQ Feed: Connecting. | 2013-03-27 13:23:20 Starting DTN IQ Feed interface software. | 2013-03-27 13:23:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:23:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:23:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:23:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:23:20 IQ Feed: Fully disconnected. | 2013-03-27 13:23:20 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:23:20 IQ Feed: Connecting. | 2013-03-27 13:26:20 Starting DTN IQ Feed interface software. | 2013-03-27 13:26:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:26:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:26:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:26:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:26:20 IQ Feed: Fully disconnected. | 2013-03-27 13:26:20 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:26:20 IQ Feed: Connecting. | 2013-03-27 13:29:20 Starting DTN IQ Feed interface software. | 2013-03-27 13:29:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:29:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:29:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:29:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:29:20 IQ Feed: Fully disconnected. | 2013-03-27 13:29:20 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:29:20 IQ Feed: Connecting. | 2013-03-27 13:32:20 Starting DTN IQ Feed interface software. | 2013-03-27 13:32:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:32:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:32:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:32:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:32:20 IQ Feed: Fully disconnected. | 2013-03-27 13:32:20 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:32:20 IQ Feed: Connecting. | 2013-03-27 13:35:20 Starting DTN IQ Feed interface software. | 2013-03-27 13:35:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:35:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:35:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:35:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:35:20 IQ Feed: Fully disconnected. | 2013-03-27 13:35:20 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:35:20 IQ Feed: Connecting. | 2013-03-27 13:38:20 Starting DTN IQ Feed interface software. | 2013-03-27 13:38:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:38:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:38:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:38:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:38:20 IQ Feed: Fully disconnected. | 2013-03-27 13:38:20 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:38:20 IQ Feed: Connecting. | 2013-03-27 13:41:20 Starting DTN IQ Feed interface software. | 2013-03-27 13:41:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:41:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:41:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:41:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:41:20 IQ Feed: Fully disconnected. | 2013-03-27 13:41:20 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:41:20 IQ Feed: Connecting. | 2013-03-27 13:44:20 Starting DTN IQ Feed interface software. | 2013-03-27 13:44:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:44:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:44:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:44:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:44:20 IQ Feed: Fully disconnected. | 2013-03-27 13:44:20 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:44:20 IQ Feed: Connecting. | 2013-03-27 13:47:20 Starting DTN IQ Feed interface software. | 2013-03-27 13:47:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:47:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:47:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:47:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:47:20 IQ Feed: Fully disconnected. | 2013-03-27 13:47:20 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:47:20 IQ Feed: Connecting. | 2013-03-27 13:50:20 Starting DTN IQ Feed interface software. | 2013-03-27 13:50:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:50:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:50:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:50:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:50:20 IQ Feed: Fully disconnected. | 2013-03-27 13:50:20 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:50:20 IQ Feed: Connecting. | 2013-03-27 13:53:20 Starting DTN IQ Feed interface software. | 2013-03-27 13:53:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:53:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:53:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:53:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:53:20 IQ Feed: Fully disconnected. | 2013-03-27 13:53:20 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:53:20 IQ Feed: Connecting. | 2013-03-27 13:56:20 Starting DTN IQ Feed interface software. | 2013-03-27 13:56:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:56:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:56:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:56:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:56:20 IQ Feed: Fully disconnected. | 2013-03-27 13:56:20 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:56:20 IQ Feed: Connecting. | 2013-03-27 13:59:20 Starting DTN IQ Feed interface software. | 2013-03-27 13:59:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 13:59:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 13:59:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 13:59:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 13:59:20 IQ Feed: Fully disconnected. | 2013-03-27 13:59:20 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 13:59:20 IQ Feed: Connecting. | 2013-03-27 14:02:20 Starting DTN IQ Feed interface software. | 2013-03-27 14:02:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:02:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:02:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:02:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:02:20 IQ Feed: Fully disconnected. | 2013-03-27 14:02:20 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:02:20 IQ Feed: Connecting. | 2013-03-27 14:05:20 Starting DTN IQ Feed interface software. | 2013-03-27 14:05:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:05:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:05:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:05:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:05:20 IQ Feed: Fully disconnected. | 2013-03-27 14:05:20 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:05:20 IQ Feed: Connecting. | 2013-03-27 14:08:20 Starting DTN IQ Feed interface software. | 2013-03-27 14:08:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:08:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:08:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:08:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:08:20 IQ Feed: Fully disconnected. | 2013-03-27 14:08:20 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:08:20 IQ Feed: Connecting. | 2013-03-27 14:11:20 Starting DTN IQ Feed interface software. | 2013-03-27 14:11:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:11:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:11:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:11:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:11:20 IQ Feed: Fully disconnected. | 2013-03-27 14:11:20 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:11:20 Error loading custom studies DLL: C:\SierraChart\Data\OFE_ZoneWidth.dll. Windows Windows error code 126: The specified module could not be found. | 2013-03-27 14:14:09 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM3-CME.scid | 2013-03-27 14:14:09 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM3-CME.scid | 2013-03-27 14:14:09 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM3-CME.scid | 2013-03-27 14:14:09 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM3-CME.scid | 2013-03-27 14:14:09 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\$NSHF.scid | 2013-03-27 14:14:09 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\$TICK.scid | 2013-03-27 14:14:09 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM3-CME.scid | 2013-03-27 14:14:09 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM3-CME.scid | 2013-03-27 14:14:09 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM3-CME.scid | 2013-03-27 14:14:09 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM3-CME.scid | 2013-03-27 14:14:09 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQM3-CME.scid | 2013-03-27 14:14:09 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\$NVLF.scid | 2013-03-27 14:14:09 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM3-CME.scid | 2013-03-27 14:14:09 IQ Feed: Connecting. | 2013-03-27 14:14:20 Starting DTN IQ Feed interface software. | 2013-03-27 14:14:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:14:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:14:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:14:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:14:20 IQ Feed: Fully disconnected. | 2013-03-27 14:14:20 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:14:20 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:15:20 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:15:20 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:15:20 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:15:21 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:15:22 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:15:22 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:15:22 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:15:23 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:15:23 IQ Feed: Connecting. | 2013-03-27 14:15:58 Starting DTN IQ Feed interface software. | 2013-03-27 14:15:58 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:15:58 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:15:58 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:15:58 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:15:58 IQ Feed: Fully disconnected. | 2013-03-27 14:15:58 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:15:58 IQ Feed: Connecting. | 2013-03-27 14:18:58 Starting DTN IQ Feed interface software. | 2013-03-27 14:18:58 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:18:58 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:18:58 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:18:58 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:18:58 IQ Feed: Fully disconnected. | 2013-03-27 14:18:58 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:18:58 IQ Feed: Connecting. | 2013-03-27 14:21:58 Starting DTN IQ Feed interface software. | 2013-03-27 14:21:58 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:21:58 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:21:58 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:21:58 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:21:58 IQ Feed: Fully disconnected. | 2013-03-27 14:21:58 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:21:58 IQ Feed: Connecting. | 2013-03-27 14:22:27 Starting DTN IQ Feed interface software. | 2013-03-27 14:22:27 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:22:27 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:22:27 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:22:27 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:22:27 IQ Feed: Fully disconnected. | 2013-03-27 14:22:27 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:22:27 IQ Feed: Connecting. | 2013-03-27 14:22:29 Starting DTN IQ Feed interface software. | 2013-03-27 14:22:29 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:22:29 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:22:29 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:22:29 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:22:29 IQ Feed: Fully disconnected. | 2013-03-27 14:22:30 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:22:30 IQ Feed: Connecting. | 2013-03-27 14:25:30 Starting DTN IQ Feed interface software. | 2013-03-27 14:25:30 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:25:30 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:25:30 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:25:30 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:25:30 IQ Feed: Fully disconnected. | 2013-03-27 14:25:30 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:25:30 IQ Feed: Connecting. | 2013-03-27 14:28:30 Starting DTN IQ Feed interface software. | 2013-03-27 14:28:30 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:28:30 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:28:30 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:28:30 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:28:30 IQ Feed: Fully disconnected. | 2013-03-27 14:28:30 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:28:30 IQ Feed: Connecting. | 2013-03-27 14:31:30 Starting DTN IQ Feed interface software. | 2013-03-27 14:31:30 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:31:30 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:31:30 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:31:30 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:31:30 IQ Feed: Fully disconnected. | 2013-03-27 14:31:30 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:31:30 IQ Feed: Connecting. | 2013-03-27 14:34:30 Starting DTN IQ Feed interface software. | 2013-03-27 14:34:30 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:34:30 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:34:30 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:34:30 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:34:30 IQ Feed: Fully disconnected. | 2013-03-27 14:34:30 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:34:30 IQ Feed: Connecting. | 2013-03-27 14:37:30 Starting DTN IQ Feed interface software. | 2013-03-27 14:37:30 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:37:30 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:37:30 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:37:30 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:37:30 IQ Feed: Fully disconnected. | 2013-03-27 14:37:30 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:37:30 IQ Feed: Connecting. | 2013-03-27 14:40:30 Starting DTN IQ Feed interface software. | 2013-03-27 14:40:30 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:40:30 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:40:30 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:40:30 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:40:30 IQ Feed: Fully disconnected. | 2013-03-27 14:40:30 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:40:30 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM3-CME.scid | 2013-03-27 14:42:31 IQ Feed: Connecting. | 2013-03-27 14:43:30 Starting DTN IQ Feed interface software. | 2013-03-27 14:43:30 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:43:30 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:43:30 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:43:30 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:43:30 IQ Feed: Fully disconnected. | 2013-03-27 14:43:30 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:43:30 IQ Feed: Connecting. | 2013-03-27 14:44:12 Starting DTN IQ Feed interface software. | 2013-03-27 14:44:12 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:44:12 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:44:12 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:44:12 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:44:12 IQ Feed: Fully disconnected. | 2013-03-27 14:44:12 Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:44:12 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:44:18 File >> Disconnect selected. | 2013-03-27 14:45:50 Reconnect canceled. | 2013-03-27 14:45:50 IQ Feed: Fully disconnected. | 2013-03-27 14:45:50 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:46:19 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:46:19 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:46:21 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:46:33 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:46:33 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:46:33 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:46:33 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:46:34 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:46:34 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:46:34 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:46:34 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:46:34 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:46:34 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:46:34 IQ Feed: Connecting. | 2013-03-27 14:48:00 Starting DTN IQ Feed interface software. | 2013-03-27 14:48:00 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:48:00 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:48:00 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:48:00 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:48:00 IQ Feed: Fully disconnected. | 2013-03-27 14:48:00 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:48:00 IQ Feed: Connecting. | 2013-03-27 14:48:05 Starting DTN IQ Feed interface software. | 2013-03-27 14:48:05 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:48:05 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:48:05 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:48:05 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:48:05 IQ Feed: Fully disconnected. | 2013-03-27 14:48:05 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:48:05 IQ Feed: Connecting. | 2013-03-27 14:48:10 Starting DTN IQ Feed interface software. | 2013-03-27 14:48:10 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:48:10 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:48:10 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:48:10 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:48:10 IQ Feed: Fully disconnected. | 2013-03-27 14:48:10 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:48:10 IQ Feed: Connecting. | 2013-03-27 14:48:15 Starting DTN IQ Feed interface software. | 2013-03-27 14:48:15 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:48:15 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:48:15 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:48:15 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:48:15 IQ Feed: Fully disconnected. | 2013-03-27 14:48:15 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:48:15 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:48:15 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:48:15 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:48:16 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:48:16 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:48:16 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:48:16 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:48:16 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:48:16 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:48:16 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:48:16 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:48:16 IQ Feed: Connecting. | 2013-03-27 14:48:20 Starting DTN IQ Feed interface software. | 2013-03-27 14:48:20 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:48:20 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:48:20 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:48:20 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:48:20 IQ Feed: Fully disconnected. | 2013-03-27 14:48:20 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:48:20 IQ Feed: Connecting. | 2013-03-27 14:48:25 Starting DTN IQ Feed interface software. | 2013-03-27 14:48:25 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:48:25 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:48:25 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:48:25 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:48:25 IQ Feed: Fully disconnected. | 2013-03-27 14:48:25 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:48:25 IQ Feed: Connecting. | 2013-03-27 14:48:30 Starting DTN IQ Feed interface software. | 2013-03-27 14:48:30 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:48:30 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:48:30 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:48:30 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:48:30 IQ Feed: Fully disconnected. | 2013-03-27 14:48:30 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:48:30 IQ Feed: Connecting. | 2013-03-27 14:48:35 Starting DTN IQ Feed interface software. | 2013-03-27 14:48:35 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:48:35 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:48:35 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:48:35 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:48:35 IQ Feed: Fully disconnected. | 2013-03-27 14:48:35 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:48:35 IQ Feed: Connecting. | 2013-03-27 14:48:40 Starting DTN IQ Feed interface software. | 2013-03-27 14:48:40 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:48:40 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:48:40 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:48:40 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:48:40 IQ Feed: Fully disconnected. | 2013-03-27 14:48:40 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:48:40 IQ Feed: Connecting. | 2013-03-27 14:48:45 Starting DTN IQ Feed interface software. | 2013-03-27 14:48:45 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:48:45 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:48:45 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:48:45 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:48:45 IQ Feed: Fully disconnected. | 2013-03-27 14:48:45 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:48:45 IQ Feed: Connecting. | 2013-03-27 14:48:50 Starting DTN IQ Feed interface software. | 2013-03-27 14:48:50 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:48:50 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:48:50 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:48:50 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:48:50 IQ Feed: Fully disconnected. | 2013-03-27 14:48:50 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:48:50 IQ Feed: Connecting. | 2013-03-27 14:48:55 Starting DTN IQ Feed interface software. | 2013-03-27 14:48:55 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 14:48:55 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 14:48:55 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-03-27 14:48:55 To prevent further connection attempts, select File >> Disconnect. | 2013-03-27 14:48:55 IQ Feed: Fully disconnected. | 2013-03-27 14:48:55 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-03-27 14:48:55 File >> Disconnect selected. | 2013-03-27 14:49:00 Reconnect canceled. | 2013-03-27 14:49:00 IQ Feed: Fully disconnected. | 2013-03-27 14:49:00 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:49:08 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:49:08 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:49:08 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:49:08 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:49:08 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:49:08 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:49:08 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:49:08 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:49:08 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:49:08 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:49:08 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:49:08 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:49:08 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:49:08 Base Graph DateTime: Array is unallocated. | 2013-03-27 14:49:09 The above log is being sent to support. | 2013-03-27 14:53:46 Sending of the message log was completed. Please read the response that was received. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2013-03-27 14:53:47 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM3-CME.scid | 2013-03-27 15:00:41 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM3-CME.scid | 2013-03-27 15:00:41 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM3-CME.scid | 2013-03-27 15:00:41 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM3-CME.scid | 2013-03-27 15:00:41 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\$NSHF.scid | 2013-03-27 15:00:41 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\$TICK.scid | 2013-03-27 15:00:41 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM3-CME.scid | 2013-03-27 15:00:41 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM3-CME.scid | 2013-03-27 15:00:41 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM3-CME.scid | 2013-03-27 15:00:41 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM3-CME.scid | 2013-03-27 15:00:41 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQM3-CME.scid | 2013-03-27 15:00:41 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\$NVLF.scid | 2013-03-27 15:00:41 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM3-CME.scid | 2013-03-27 15:00:41 IQ Feed: Connecting. | 2013-03-27 15:00:59 Starting DTN IQ Feed interface software. | 2013-03-27 15:00:59 Error starting IQ Feed interface software. Error code: 2 | 2013-03-27 15:00:59 IQ Feed: Failed to look up the port number for the Admin connection. | 2013-03-27 15:00:59 |
[2013-03-27 20:37:52] |
Your Sierra Chart is not configured to use Interactive Brokers. Please follow through the step-by-step instructions here: http://www.sierrachart.com/index.php?l=doc/IB.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
