Date/Time: Fri, 29 Mar 2024 10:23:11 +0000
symbol is unknown...
View Count: 1599
[2013-06-20 17:27:08] |
We had someone else report this as well. The symbols you are using are correct. Could you please contact your broker about this and make sure your account is authorized for those symbols.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-20 17:27:31
