Date/Time: Tue, 23 Apr 2024 22:35:22 +0000
[User Discussion] - Conditional Formating for Studies
View Count: 1798
[2013-06-19 21:22:21] |
drywater0 - Posts: 85 |
Is there a way to apply conditional formatting to studies? For example, the Rate of Change-Percent indicator would be drawn in a different color or with a thicker line when it has an absolute value that exceeds a certain threshold. Thanks for your help.
[2013-06-20 01:57:40] |
You need to create a custom study that does this. Please refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html We do not provide programming help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-20 02:27:46] |
Sawtooth - Posts: 3976 |
A variation of this can easily be done with the Color Bar Based On Alert Condition study. This study cannot overdraw a line of a different color or width, but it can place points, squares, background colors, or other non-connecting draw styles when values exceed a certain threshold. You could also change the draw style of the ROC study to a non-connecting draw style, and then the Color Bar Based On Alert Condition study could be set to the same draw style but a different color or width. If you want to pursue this solution, post again and I'll provide an example. |
