Date/Time: Thu, 18 Apr 2024 23:21:45 +0000
Please can you give connection setting to LMAX trading service
View Count: 2468
[2013-03-27 19:03:02] |
You need to obtain FIX connection information from LMAX for your LMAX account. Also make certain you are on the very latest Sierra Chart version. Update with Help >> Download Prerelease. If LMAX does not give you the FIX information, it is because we have not yet completed the conformance test. That will be completed over the next few days. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-03-27 19:03:34
[2013-04-02 22:44:24] |
We should be ready within the next few days. We will be doing the conformance test tomorrow as I understand.
[2013-04-03 04:16:26] |
trading4roy - Posts: 6 |
Please let me know as well Thank You
[2013-04-03 04:26:25] |
OK.
