Date/Time: Thu, 28 Mar 2024 10:04:12 +0000
Sierra Chart in two computers
View Count: 1401
[2013-06-16 13:47:16] |
User96015 - Posts: 55 |
Hello, The question is the follow: I have already a direct account with you, that actually I' m using with IB. I would like to know, if I can use the same SierraChart account in another pc with another broker and specifically with DDT via TT FIX. Thanks |
[2013-06-16 21:02:08] |
Yes.
