Date/Time: Thu, 28 Mar 2024 10:19:30 +0000
Can anyone explain this and perhaps a solution?
View Count: 1390
[2013-06-16 13:08:37] |
narcese - Posts: 58 |
only a few pairs will roll up, most other pairs charts open up just fine. Is there a bug or solution?
MWSnap081 6-16 9-02 am.bmp - Attached On 2013-06-16 13:07:05 UTC - Size: 4.12 MB - 507 views Attachment Deleted. |
[2013-06-16 20:21:18] |
Go to a chart for each symbol which has data errors and select Edit >>Delete All Data and Download.
