Date/Time: Fri, 19 Apr 2024 14:25:50 +0000
charts not updating
View Count: 1492
[2013-06-13 16:26:44] |
Please refer to help topic 3 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails3.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-13 20:48:38] |
You are able to edit your post by clicking on the "Edit" link at the lower left of the post. We see that you are using the Sierra Chart Historical Data Service. That service does not provide streaming data which continuously updates the charts. You will need to use another service that provides streaming data. Please see: https://www.sierrachart.com/index.php?l=doc/data.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-13 20:49:06
