Date/Time: Sat, 20 Apr 2024 09:11:28 +0000
frozen charts
View Count: 785
[2015-08-12 19:46:04] |
It sounds like "this page has been corrupted" comes from your web browser? We recommend restarting your computer and running Sierra Chart again. For the high CPU usage (freezing) problem, refer to help topic 30: http://www.sierrachart.com/index.php?page=doc/helpdetails30.html The two most important things are to increase the Chart Update Interval to 1000 ms and to not use any existing Chartbooks until the source of the problem can be determined. In the page linked to above, these are subsections: 30.5 and 30.16. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-12 20:06:09
