Date/Time: Thu, 18 Apr 2024 19:06:10 +0000
Titleless columns keep re-appear in Spreadsheet for Trading
View Count: 744
[2015-07-27 17:12:37] |
BataviaTrader - Posts: 63 |
Whatever I do (deleting and saving), in my spreadsheet columns keep showing up filled with data but without title. So basically I don't know what indicator these data represent. When deleted, these columns show up again next time I open SC. Also, when I save a Spreadsheet giving it a dedicated name, it does not reappear automatically next time with the chart I attached it to. When I open the saved spreadsheet, it give old data and is not live / moving with price.
[2015-07-27 17:51:24] |
Attach a screenshot showing the top of these columns so we have a better understanding of this. Here are instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Also, when I save a Spreadsheet giving it a dedicated name, it does not reappear automatically next time with the chart I attached it to. You also need to set the same name in the Spreadsheet Name box on the Study Settings window for this Spreadsheet study.
[2015-07-27 18:34:39] |
http://www.sierrachart.com/image.php?l=1438021963928.png
[2015-07-27 18:39:28] |
If you delete the entire AF column, does it reappear when you go to the chart and select Chart >> Recalculate?
[2015-07-27 19:14:27] |
Yes it does reappear.
[2015-07-27 19:50:47] |
We need to know what study that is from. Remove one study at a time from the chart and determine which study is causing that column to reappear.
