Date/Time: Thu, 22 Jan 2026 06:36:42 +0000
Moving Average Simple with SCDateTime input
View Count: 1629
[2015-07-26 22:04:31]
User53601 - Posts: 107
I have the following studies in the Graph :
1.)  Bar Time Duration
2.)  Moving Average Simple
- Input data is subgraph from BarTimeDuration study – DURATION, which is a SCDateTime type
So far I got the moving average from Bar Time duration.
Now I wanted to get this subgraph to my ACSIL study. However, I have some problem, I get zero values only.
Here I imported the Bar Time Duration Average
sc.GetStudyArrayUsingID(3,0,BarTimeDurationAverage);
Then I wanted to get the value from BarTimeDurationAverage array.
I am not sure what is the type of output Subgraph AVG in the Moving Average Simple,
whether it is SCDateTime or float type or something else.
That is why, I tried these two ways how to get the Moving average values, however, both ways give me zero values:
as INT variable: TIME_PART(BarTimeDurationAverage[sc.Index]
as FLOAT variable: BarTimeDurationAverage[sc.Index]
can you help with this, thank you
[2015-07-27 04:56:50]
The Bar Time Duration Subgraph contains SCDateTime values stored as 4-byte floating-point values.
How have you defined this:
And if you check the size of it after getting the array, is it zero?
Both of these are valid:
as INT variable: TIME_PART(BarTimeDurationAverage[sc.Index])
Date Time Of Last Edit: 2015-07-27 04:57:26
[2015-07-27 21:26:31]
(I used this definition: SCFloatArray BarTimeDurationAverage )
I did another check, and found out the values are correct, my excuse.
However when I want to display the value, it gives me the zero value:
sc.FormatString(Text01," %.1f ", BarTimeDurationAverage[sc.Index] )
[2015-07-28 05:31:02]
Where is the mistake? For the formatting string, only use %f. You need at least six digits of precision.
[2015-07-28 07:46:27]
Now it is clear, thank you.
