Date/Time: Fri, 19 Apr 2024 04:01:42 +0000
sierra chart running slowly and freezing
View Count: 1488
[2013-06-10 15:47:37] |
User19537 - Posts: 9 |
This morning I have been running SC and it seems to load the charts fine and tick for a little bit, but then freezes. I use transact for data - and they seem to be fine as data is ticking on their software when i log in directly. please advise as to possible solution. the only thing that seems to work is if I exit and log back in, but then it freezes again anyway.
[2013-06-10 16:15:25] |
Please contact TransAct support about this. They are responsible for the data feed. For now, when you notice this, select File >> Disconnect and then File >> Connect to Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-10 16:15:44
