Date/Time: Thu, 25 Apr 2024 16:17:23 +0000
Setting up indexes with DTN IQ data
View Count: 1302
[2013-06-10 03:01:38] |
User78882 - Posts: 4 |
I'm wanting to set up several indexes to display on my .scwbf. When I add certain symbols to the spreadsheet nothing comes up. One of the indexes for example that I want to add is: NYSE FINANCIAL INDX NYK.ID.X How do I get this data to display? |
[2013-06-10 03:18:23] |
The symbol to use is: NYK.ID.X If you are using a Spreadsheet for quotes, you need to actually enter the symbol as #NYK.ID.X in column A. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
