Date/Time: Fri, 29 Mar 2024 07:46:02 +0000
Sierra Charts Virtual Private Servers
View Count: 2192
[2013-06-10 02:46:20] |
rwilliams1 - Posts: 339 |
I have searched all over for trading VPS servers that host and have Sierra Charts already configured on their servers. I remember seeing one company that offered this months ago, but I cannot find it anywhere now. I'm curious if you know of any VPS companies that have SC preconfigured on their servers? Thanks.
[2013-06-10 03:10:35] |
Sierra Chart is very easy to install on a Windows server. You just run the Sierra Chart installer and put it in whatever folder you want on the server. You can get a good VPS from many sources. Get one and then just simply install Sierra Chart. You are not going to have any difficulty with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-10 04:54:48] |
Thanks, I am aware that I can easily install SC on a VPS. But I was actually asking if you have knowledge of any companies that already have SC installed, configured and optimized for use. I remembered seeing one a few months back but can't recall the name of the service.
Date Time Of Last Edit: 2013-06-10 04:55:13
[2013-06-10 07:14:09] |
TastyRisk - Posts: 119 |
I've never seen this offered and I've shopped for / used quite a few VPSs'. |
[2013-06-10 07:22:59] |
Never heard of this and really we do not see how Sierra Chart could be preconfigured or optimized. You have to configure it yourself and what you do with Sierra Chart determines the load on the system. Which normally is minimal.
[2013-06-10 07:38:51] |
Yes, I was surprised to see it myself. I came across the company by accident and was surprised that this service was offered. I don't know what they meant by optimized, but I assume they probably meant they are familiar with SC and its resources and therefore can configure their servers for the best setup regardless of the individual user configuration. Anyway, if I come across it again and do eventually find the site, I will forward the info to you as it may also be of help to some of your other customers. |
