Date/Time: Thu, 25 Apr 2024 14:19:46 +0000
Autotrader chartbook
View Count: 1545
[2015-06-26 23:13:08] |
User636069 - Posts: 26 |
Hello, I am going to develop a autotrading chartbook by Sierra. A program which is able to read the data from one chart and place order (buy/sell) in price chart. How can I do that? Does sierra platform offer any settings to automate the system for auto trading? Thanks in advance. |
[2015-06-27 02:12:55] |
Yes this can be done. The only thing we can do is refer you to the general documentation. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_AutoTradeManagment.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-28 00:59:04] |
Hello, I have two separate auto-trading chart books using Spreadsheet system for autotrading study. How can I disable one a enable the other one? "Make certain there is a check mark by Trade >> Auto Trading Enabled so the TRUE results that your Condition Formulas provide" enable all the chart books open. How to auto-trade on one specific chartbook. Thanks |
[2015-07-28 01:18:17] |
Sawtooth - Posts: 3976 |
Use cell J28.
[2015-07-28 01:40:55] |
Thanks, Is there any way to do that in the main chart? for example by right click on the chart and then check the Disable/Enable Auto Trading?
[2015-07-28 02:47:22] |
Unfortunately, no. You can reference J28 from H1, e.g., and then fix rows 1 and 2 to always be at the top of the sheet, then drag the corner of the sheet to make it small to park it somewhere. If you are using the same-named spreadsheet for both charts, you can reference both sheets' J28 from one sheet's H1 and H2, e.g. This is probably the best workaround. |
[2015-07-28 03:17:12] |
We will see about adding a chart specific auto trading enabled option.
