Date/Time: Thu, 25 Apr 2024 00:46:24 +0000
help with some tools!
View Count: 1616
[2013-06-06 13:48:37] |
User25261 - Posts: 24 |
hi, 1-i want to know how i drawing for more than one chart.for example im using 60 min,30min and 14 minchart and i want to copy all the lines with i draw in this charts to my mean trading chart which is 5 min chart.How i do this? 2-do you have some indicator wich draw automaticly the double bottom when its happen? 3-im using SC level 3+TT and i want to have more than 300 historical data days in my mean trading chart,how i can get it? BR |
[2013-06-06 18:05:22] |
1. Refer to: https://www.sierrachart.com/index.php?l=doc/helpdetails72.html 2. No. 3. Is this a Historical Daily or Intraday Chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-06 18:12:02] |
intraday chart. i was ask a lot question befor and i get all the answer.how i can find all my previous support request which i post befor? |
[2013-06-06 23:11:23] |
For a 300 day Intraday futures chart, refer to Method 1 here: https://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
