Date/Time: Fri, 19 Apr 2024 03:30:49 +0000
Programming of position closing
View Count: 1390
[2013-06-06 07:41:02] |
Michaela Nepovimova - Posts: 8 |
Good morning, I would like to close my position in moment when the violet line (slow MA 26) crosses the 0 line but not manually or touching stop loss. I would like to computer do that instead of me at this moment. So automatically. Is it possible? If it is, please describe me detaily how to do that including the data I should put to program it. Thank you in advance for help. Have a nice day, Michaela |
[2013-06-07 06:50:05] |
You can do this using the Spreadsheet System for Trading study: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php Be sure to take note of this particular section here: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#AutomatedAdvancedExitStrategies If you need further help, we recommend contacting someone from this page: https://www.sierrachart.com/index.php?l=doc/SierraChartStudyAndSystemProgrammers.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-07 06:51:10
