Date/Time: Fri, 19 Apr 2024 12:04:08 +0000
TD Ameritrade Data - Problem with Stock Splits
View Count: 2681
[2013-06-06 01:09:29] |
lou_diamonds - Posts: 39 |
Is it a bug that all the stocks that split when using the TD Ameritrade data or am I doing something wrong. Take CRM for example. The stock goes from the $140's to the $30's. What do I need to do? |
[2013-06-06 01:15:45] |
Re-download the data in the chart by selecting Edit >>Delete All Data and Download.
[2013-06-06 01:18:44] |
Works like a charm! Thanks!
