Date/Time: Thu, 15 Jan 2026 23:44:52 +0000
Daily Charts dont match
View Count: 977
| [2015-06-02 14:55:34] |
| MKL17 - Posts: 35 |
I have two daily charts which I have screenshot-ed and attached as a file here. Basically, the settings on these are the same however the charts differ, specfically todays bar. It seems the daily charts include pre-post market sometimes but I am not quite sure how to make sure my dailies are the same or if there is a way to only include the day market with no pre or post.
| [2015-06-02 15:49:44] |
Go to each of those charts and select Chart >> Reload and Recalculate. That should make them match.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-02 15:50:18
