Date/Time: Fri, 29 Mar 2024 13:45:00 +0000
Number Bars V2 Issue
View Count: 1485
[2013-06-06 00:07:22] |
1. Please refer to this page for tick by tick data configuration: http://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php The chart data file probably does not have tick by tick data. 2. From documentation: In the case of the Bid Vol x Ask Vol Text type, the price level with the maximum AskVolume for the Numbers Bar column is considered the maximum value and will be highlighted.
What you could do is configure the Numbers Bars study to add an additional Numbers Bar column and set the Text Type to display Total Volume. 3. You need to use a supported data feed which consistently provides tick by tick data. The best ones we have seen are going to be IQ Feed, CTS T4 and Rithmic. The reason for the delay with responding is that this request took more research time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-06 00:11:20
