Date/Time: Sun, 15 Feb 2026 05:52:53 +0000
seconds chart
View Count: 1740
| [2015-05-27 17:40:23] |
| Dennis B. - Posts: 297 |
After upgrading to 1254 I can no longer get a 30 second ES chart or a ! min 30 sec for that matter.
| [2015-05-27 18:16:38] |
This is not clear for us. So what happens when you change the chart to 30 seconds per bar?
| [2015-05-27 18:29:47] |
When I try to change a @ESM15 2 min chart to a 30 second chart I get...@ES#H12 2 Min and the chart is blank no grid, nothing.
| [2015-05-27 18:33:49] |
Most likely you tried to change the bar timeframe directly from the chart window itself and there were previous characters in the key buffer. Next time before doing this, press the Escape key first. Change the symbol back to the correct one through Chart >> Chart Settings >> Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-05-27 18:58:31] |
Before no problem, typed in 30 seconds... bang a 30 second chart. Have no idea what you're talking about. Will stumble around and figure it out.
| [2015-05-27 20:46:05] |
You need to type 30s
| [2015-05-28 14:35:03] |
Yup, that did it...I knew something had changed.
| [2015-05-28 16:48:51] |
The word seconds apparently previously worked but was not considered the correct suffix. And there were changes with supporting new time period suffixes and this is what triggered the problem.
