Date/Time: Tue, 23 Apr 2024 06:08:55 +0000
Color Arrows
View Count: 1715
[2013-06-05 14:25:47] |
User56044 - Posts: 62 |
My choices of colors for arrows seems to have changed. How can I install a particular color, or change the choice of available colors, in the palette in the drop down color menu?
[2013-06-05 21:31:07] |
Are you referring to Tools >> Arrow?
[2013-06-05 22:52:20] |
Yes. Draw an arrow, with the pointer over that arrow right click on "color", and 8 color choices are displayed. How do I change one of the color options to a color I prefer?
[2013-06-06 03:19:04] |
This is documented here: https://www.sierrachart.com/index.php?l=doc/doc_Tools.html#QuicklyChangingColors Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
