Date/Time: Sun, 07 Dec 2025 10:31:31 +0000
display layers
View Count: 1309
| [2015-05-24 19:30:28] |
| User97684 - Posts: 136 |
Hi , Please how can I organise the layers to display one over the other, i.e. is there a way for me to organise what is on top, what is second, third layer of lines. See picture attached - for example I would like to display the numbers and letters above the lines, how can I achieve that? Thanks |
| [2015-05-26 05:56:37] |
You need to set Chart Drawings to display above the main price graph and studies. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DisplayOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
