Date/Time: Sat, 12 Sep 2026 08:39:07 +0000
upgraded from pkg 3 to 5
View Count: 1313
| [2015-04-30 00:40:03] |
| User53283 - Posts: 6 |
upgraded from pkg 3 to 5 made the change on website, closed and reopened charts, no access to pkg 5 options. thanks, Gary |
| [2015-04-30 02:34:54] |
Restart Sierra Chart and follow the instructions here to force a login: Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name Sierra Chart Support |
| [2015-04-30 04:12:36] |
If you are still having a problem, restart Sierra Chart and on the login window enable the "Force Login" option.
