Date/Time: Sun, 11 Oct 2026 08:29:02 +0000
How to disable the changing the quantity of contracts in trading DOM
View Count: 1314
| [2015-04-21 10:13:05] |
| Alexander - Posts: 18 |
Is there any way to disable the possibility of changing the quantity of contracts in the trading DOM? E.g. to not type by mistake 10 instead 1 in the Quantity box. Thank you in advance Alexander |
| [2015-04-22 04:49:38] |
No, this is not supported. But eventually we will add the capability to limit the maximum number of contracts.
