Date/Time: Sat, 20 Apr 2024 01:08:07 +0000
OEC 5 Symbol Limit
View Count: 1922
[2013-05-28 16:18:21] |
Paul.M - Posts: 113 |
Currently OEC has a limit of 5 symbols. This means you can only get tick by tick updates on up to 5 symbols at a time.
Why this limit ? Is the cause Sierra or OEC ? OEC has not such limit on their free platform. Are there plans to increase simultaneous symbols? Why is November 2013 Soybeans not working. It works on the OEC trader. Please advice, TY |
[2013-05-28 16:20:57] |
will your change to FIX affect this ? Is this related ?
[2013-05-28 16:27:48] |
This limit is imposed by OEC. Using FIX we would not think would change this. What exactly is not working with November 2013 Soybeans ? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-28 17:28:09] |
Soybeans Nov13 I dont get intraday realtime quotes from OEC. (I am below the limit ) |
[2013-05-28 17:46:08] |
Please post a copy of the Message Log, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-28 17:56:24] |
I used "Send for Analysis "
[2013-05-28 20:58:46] |
We see the problem and we are working on it. We will follow up here.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-28 20:58:58
[2013-05-28 21:40:51] |
This is now resolved. please go to the ZS chart and select Edit >>Delete All Data and Download.
