Date/Time: Fri, 19 Apr 2024 20:40:37 +0000
time frame to export data
View Count: 1944
[2013-05-27 18:25:10] |
942abel - Posts: 7 |
hello I want to export historical data in different time frames on the ES future. My problem is that only exported in time frame of one minute, and would like to download in 1 minute, 5 minutes, 15 minutes or ticks. How do I change that option? Another question is how to export the historical data maximum. I can export only 6 months in 1 minute time frame. thanks (my broker is Interactive Brokers) Date Time Of Last Edit: 2013-05-27 18:28:22
[2013-05-27 19:01:46] |
Sierra Chart - Max - Posts: 5590 |
The Write Bar Data to File would be useful to do what want: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s182 Sierra Chart Support |
[2013-05-27 22:20:18] |
Also, refer to this page: http://www.sierrachart.com/index.php?l=doc/doc_ImportExport.html#ExportAlternatives Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-28 16:10:04] |
thanks for the info, but my problem continues when I export the data, the data are not continuous, from October 2012 to March 2013. and the maximum number of historical time is 7 months And I still can export to other time frames. Someone could send me the future historical ES and help me to do it myself. thank you very much |
[2013-05-28 16:36:43] |
What do you mean by "data are not continuous"? To obtain more historical Intraday data, refer to help topic 42.1 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails42.html If you are having trouble getting a lot of data from Interactive Brokers, please be advised that we do not provide help with that. You will have difficulties with that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
